Z06 exhaust sound and hearing issues
The car with the windows up inside is close to 110 dB in Z mode. I’m already starting to get ringing of the ears and issues with hearing. What are you guys doing about the insanely loud car?
Popular Reply
06-26-2023, 07:49 PM
It could be close depending on the road conditions. I just took a 1400 mi round trip in my C6 Z06 with Corsa Xtreme exhaust and after I had new tires installed 200 mi into the trip I downloaded a dB app because it was very loud inside the cabin. The entire cabin in my car is lined with 80 mil sound deadening material and the app was reading in the 90 dBs for a good portion of the trip. On more asphalt roads it went down to mid 80s, but the avg for the entire trip was 87 dB.
The new Z, with the 20/21 run flats, could be up there.
The following 6 users liked this post by RD-1:
540 55 (07-04-2023),
Blue Curvette (07-02-2023),
KOTYKB (06-29-2023),
LastTrueZ (06-26-2023),
Z51 John (06-27-2023),
and 1 others liked this post.
I have tinnitus and am sensitive from a hearing perspective. I don’t have much seat time in the car yet, but the car is pretty quiet in stealth mode. Sounds like you need to adjust your Z mode settings for the exhaust.
Moderator
Received 3,079 Likes
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'12, '14-'15
Just run the car in "My Mode". You can adjust (almost) all of the settings but more importantly in your case you can have the exhaust run in "Stealth" Mode all the way up to "Track Mode". Also if you run in "My Mode" when you turn the car off it will start back up in that mode instead of "Tour" which is the default mode.
As indicated above, itf the sound level bothers you, run it in Stealth mode.
The following 3 users liked this post by AzDave47:
The following 4 users liked this post by combatninja:
Received 8,875 Likes
At least it's a good sound lol
The following 7 users liked this post by AzDave47:
blue_bomber697 (06-26-2023),
CorvettoBrando (06-27-2023),
Factoid (06-29-2023),
JMB (06-26-2023),
Joefab (06-26-2023),
and 2 others liked this post.
Fun fact. I cold started with my head to close trying to film a video. Damaged my ear. The blue graph is my left ear. Oh well I still LOVE my car!
C8Zeb06 (06-28-2023)
Inside the car in My Mode with the exhaust on loudest setting I recorded 97.9db max stock.
With the Soul Performance cats I recorded 100.3db
Like others said, you don’t have to run the car in the loudest setting all the time
If you already have tinnitus and hearing issues, earplugs are the only way to go. I have custom molded silicone ones. They cost about $100, and have lasted over ten years of near daily use. You can still hear perfectly fine with them. It just drops everything down about 20 db. Save your ears!
Check out this measurement video I made. The main image and sound are from the PDR. The P-I-P is the Decibel X app running on my iPhone inside the cabin. This is a smooth asphalt road so road noise is minimal.
The mode icon is in the lower right corner. It has a gear icon when in Z-mode which I had programmed to the loudest exhaust setting. The loudest it got was ~86 dB at 7,000 RPM around 1:18 minutes.
https://youtu.be/DfsjJpy5yOs
