Lightning Lap times next Tuesday the 7th…
#261
Why isn’t the orange and the blue line being compared? They threw in the green line to show that they handle heat well and a driver who isn’t pushing for 10/10s is going to still run consistently fast in a 25 minute track session. Like doing a HPDE vs a TT, the blue being the latter.
So green vs. blue is same compound but just driver pace? I wasn't sure if it was a comparison to the existing Porsche/Mercedes compounds, suggesting they were designed for hero lap and the Corvette flavor is steady pace. The way the graph highlights that first data point as hero lap, is part of it, since if the tire was the same I'd expect that to be the same for green and blue, however obviously how they are driven would factor into that.
If green and blue are the same compound, I agree they should be compared.
The X-Axis label was also not visible so I wasn't sure if those were laps at a specific course, or purely time based, so thanks for the clarification there. Certainly in a real use case like a full session, that delta highlighted by LS6 starts to add up, but I think JVP's point was that the Lightning Lap results are more like the initial grip hero lap, so that first few data points would be the comparison. Of course again if the green vs. blue is use case of driver and not compound differences, then the PSC2R's are still significantly faster for hero lap situations.
The following 3 users liked this post by BrunoTheMellow:
#262
you guys missed the point. The blue line is the standard cup2R. The green line is the GM spec cup2R ZP. They went for a longer lasting compound. The little paragraph explains how gm worked on their own version. Essentially they wanted a tire that wouldn’t deteriorate immediately like the cup2zp and standard cup2R. It’s a win win but it makes the tire slightly slower. The GM cup2R ZP is apparently slower than the standard cup2R and old cup2ZP on first hero lap. But then those two tires overheat fast and lose 5 seconds pace by 10 laps in while the new gm cup2R ZP can stay consistently fast.
#263
Having raced mid-engined formula cars and noting that every F1 and lower formula car has been mid-engined for so many years - where in many cases you can choose whatever configuration you want - there very much is a handling and racing advantage with the mid-engined configuration.
CorvettoBrando (02-10-2023)
#264
Received 2,061 Likes
The following 2 users liked this post by PRE-Z06:
2slow2speed (02-09-2023),
JG853 (02-09-2023)
#265
In terms of all the claims about PSC2R track performance vs PSC2's one has to read GM's info and chart on the specially designed PSC2R for the C8Z06, and perhaps forget about every claim of faster this, faster that.
From GM's presentation on the bespoke PSC2R for the C8Z06
GM Tire tech Talk Slide PSC2R vs PSC2
Text in the box says: "Interestingly, MacDonald says that the Z06 breaks from the recent norm of having track tires that are at their best in the first couple of laps. For the Z06, the Corvette team worked with Michelin to create a new version of its Pilot Sport Cup 2 R's. MacDonald reports that development drivers are seeing their quickest times 10 laps in."
Zoom into the chart.
On the lap 1 hero lap, there is no more than 1 second between the 3 laptimes of the PSC2, PSC2R driven hard for a hero lap, and PSC2R driven for longevity for a 1-1/2 minute lap.
For lap 2, lap time varies from about 1:23.3 to 1:24.7 to 1:25,8, or about a variation of 2.5 seconds.
At lap 5, the green and blue curve match on terms of laptime, and then at lap 9, there is a 2 second difference in laptime between the blue and green curve.
Without knowing how hard a fresh set of tires were pushed on the first lap, everyone is just making wild guesses about the performance difference between tires. GM's development drivers would be hard to match in terms of consistency as they are the ones working with Michelin to custom design the specific version of the PSC2R for the Z06.
But the original poster of this slide said: "On the lap 1 hero lap, there is no more than 1 second between the 3 laptimes of the PSC2, PSC2R driven hard for a hero lap, and PSC2R driven for longevity for a 1-1/2 minute lap."
So the OP leads one to believe its about how it is driven, but this is conjecture on behalf of the CF poster, the actual GM slide would indicate the new tires are different than other PSC 2R tires and are fastest on laps 9 or 10.
This is entirely possible as my R60A racing slicks definitely require some hard laps to get fully up to temp for a qualifying lap and are not fastest on lap 1 or 2 like my previous Goodyears.
CPhelps (02-09-2023)
#266
GM drove test mules at the 'ring, not full production cars. And they were in traffic, with other cars to navigate around, not on a clean, empty track. There is no "time" for GM to publish.
For Porsche, getting to the ring and posting times is easy. GM has to air freight the cars and spares and equipment there, rent space to store and prep them, and if they happen to hit a bad weather streak all that money is down the drain. Why spend all that money for a car that's already in such demand people are willing to pay $50K, $100K, and even more over sticker? Breaking 7 minutes isn't going to sell one more Z07.
#267
Either way, all I was saying is that it's a little ambiguous with the legend, if it's referring to two different tire compounds (we know there are different versions for different manufacturers) or if it's the same compound, just different paces. Since as you say, whose to say you couldn't do a hero lap then back off the pace to conserve them for longer, it seems plausible that the blue and green lines are different compounds Team Corvette and Michelin were trading. That, coupled with JVP's assertion that the Rs were worse in a hero lap, is where my confusion is coming from.
Maybe some of the misunderstanding is the result of the following. The actual text box in the slide says: "Interestingly, MacDonald says that the Z06 breaks from the recent norm of having track tires that are at their best in the first couple of laps. For the Z06, the Corvette team worked with Michelin to create a new version of its Pilot Sport Cup 2 R's. MacDonald reports that development drivers are seeing their quickest times 10 laps in."
#268
Actually looking at that chart again, you will see the orange line for PSC 2 is faster on that first hero lap, than the green "consistent" PSC 2R line that presumably reflects the C8Z06/Z07 tires, just like JVP says. So I stand corrected on my earlier post of thinking it was all relative to PSC2Rs.
The LL times are NOT calculated on cold tires. They are averaged by 3 different drivers which tells me the tires have heat in them.
#269
It’s an average? Not outright best lap by any 1 person?
#270
In the discussion along with the video, the driver said something about tire warmers and being able to go fast on his early laps, and not wanting to do another sighting lap because of the tire warmers.
The following 4 users liked this post by FF2000:
#271
That’s not the way I understood it based on the legend of the colored lines in the top right corner. Obviously every tire compound has it’s optimum temp range and how hard/how long you drive around a track determines how much heat is generated, so that plays a factor on when it performs best as I know you know.
I would think that the chart would have noted the "Standard Cup2R" tire from another manufacturer in the legend if they were comparing (3) tires and not (2) tires total (Along with the title of the chart.
The following 4 users liked this post by JG853:
#272
The following 3 users liked this post by PRE-Z06:
#273
Porsche partially owns Manthey Racing...Manthey Racing is in Meuspath, right next to Nurburg. An MR prepared GT2 or 3 RS is the ultimate Porsche.....The synergy created between these two companies has helped Porsche get to the track times we see today......GM finally starting a customer racing program will hopefully create the same type of synergy and improve the product.
#274
2 seconds on a 100 second course, pretty much matches other results…
#275
Not sure when Billy Johnson wrote this, but check out the last sentence. Assume that’s a C8Z07 wheel as what other manufacturer uses 2Rs on CF wheels?
#276
https://youtu.be/Mph2RQhb8Ok
Hello Spychciu, Very interesting video ! Can you remind me the type of car 991.1 or 991.2 ? How many track days do you do with the R...can they be used at the depth limit ? Thanks in advance for your return, Best regards, Patrick
1
spychciu
1 year ago
It's a 991.2, as specified in the video description. So far used the R only once, and judging by the wear it's a 2 day tire maximum. Mind you, I'm pretty gentle on the tires, (I frequently managed 5 days on regular Cup2s and Dunlops), so if someone is pushing very hard and doing a lot of laps it can be worn out in a day of track driving. I've seen them on other cars after a single day and they did not have another full day in them. It's at the sharp end of the grip/durability spectrum.
1
Thanks a lot for your reply. Michelin says that the performance of their R tyre is very constant after a slight initial drop...can you confirm ? Patrick
1
spychciu
1 year ago
@Patrick CAMBIER on my first day on the R I beat my previous personal best on a 4 km track by almost 2 seconds on lap 40 on the tire, so that sounds about right. Didn't have the opportunity to try them out fresh having warmed myself up on a different set.
1
1
spychciu
1 year ago
1
Patrick CAMBIER
1 year agoThanks a lot for your reply. Michelin says that the performance of their R tyre is very constant after a slight initial drop...can you confirm ? Patrick
1
spychciu
1 year ago
1
#277
#278
#279
I dont think this is correct. The reported time for the Z06, a 2:38:06, was exactly the same as the best lap from the guy chasing the Lambo. His second best lap was like 1 second down, and i cant imagine anyone else got the exact same lap times.
I did notice the published time for the Z07 was the same as shown in the video, chasing the Lambo. Most of us do better in that situation.
None of my comments are to make the Z07 look bad. I'm thrilled Car and Driver was able to achieve those times. They are amazing!
#280
There are a lot of members here that like Austin - It is ironic that he posted a video showing the wear on his tires?
My friend sent me his latest video, where at 2:51 in the video he starts discussing tires from his C7 Z06/Z07 -
Interesting notes about the track camber settings that GM recommends as maximum. Also very interesting about his comments at 3:49... "I think they are the fastest tires... For sure, they are like Hot Lap Tires". (But hey, like others have mentioned in this thread, it has nothing to do with the tires. At All).
There are several advantages of the C8 Platform over the C7 Platform as has been mentioned before - And yes, Cup2R is one of them.
