GEN6 motor coming - hmmm CPC DOHC?
#141
It's not a DOHC engine now, is it?
LOL. You're applying exactly the opposite logic to trucks vs. Corvettes. Why do you think it will hurt sales of one but not the other. GM didn't provide a single update to the engine in the C7 during it's entire run. There's no reason to think they'll spend billions developing, testing and certifying a new engine for such a limited production car as the Corvette. They'll sell more Gen 6 engined trucks in a month than they sell C8s in 2 years. And they're NOT going to do a DOHC CPC engine for trucks. That design is exactly the opposite of what trucks need (high revs, low torque vs. high torque, low revs).
Wish for what you want, but there is absolutely zero evidence to support a new engine in the C8 Stingray. It's all wishful thinking.
As an aside, look at the Tundra DOHC V8 and the Nissan Titan 5.6--both 4 valve designs that make immense low end torque and I doubt rev much over 6000 rpm.
The following 6 users liked this post by d16dcoe45:
CorvettoBrando (04-05-2023),
CPhelps (03-23-2023),
GrandSport 2017 (03-23-2023),
Kodiak Bear (03-23-2023),
PRE-Z06 (03-23-2023),
and 1 others liked this post.
#142
According to Reuss that’s why GM cancelled the Volt. I own a 2017 and believe GM could have continued to evolve it as an answer to EV vehicles in urban areas that was well suited for a transitional period as we migrate towards full EV.
The following 2 users liked this post by Dominic Sorresso:
Zaro Tundov (10-05-2023)
OnPoint (03-23-2023)
#144
The following 3 users liked this post by GrandSport 2017:
#145
I Just am looking for any info I can get (non-electric related). I have an allocation coming up but if I knew June would be a GS or 2024 would have a engine or HP upgrade I'd wait.
#146
NCM Lifetime Member
Received 3,937 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
#148
How did this thread die out ? Some great info here. Is there an updated thread ?
The following 2 users liked this post by CPhelps:
CDNZR (05-27-2023),
GM Bureaucrat (05-25-2023)
#150
#151
Received 4,383 Likes
The following 2 users liked this post by Racer X:
555ctsv (05-26-2023),
smoove7410 (05-26-2023)
#152
I'm holding out hope for a 575-600hp C8 but I think it is far more likely that this power plant debuts in the trucks first and then the C9 in 2028-29. What would be interesting is to see if the engineers could get proper traction management with that kind of power level with the 305s on the back of the Stingray. They may have to go up to a 315 or 325 and/or detune the engine in order to balance the power and grip for the 0-60 time of 2.8 that everyone will expect/demand. I'd still be fine with a 550hp naturally aspirated Corvette that could rev to 7000+ with a warranty.
The following 2 users liked this post by combatninja:
CDNZR (05-27-2023),
TTc8HTC@gmail.com (05-26-2023)
#154
Yes,
Say a small horizontally opposed twin on gasoline putting out 15-20 Kw to charge batteries when no grid is available, and extend the range as well as either reducing the peak battery loads and/or adding extra performance boost. Battery size and weight is reduced. Car comes in well under 4000 lbs.
Would you buy it for 85k?
In a Corvette: HARD PASS.
GM Bureaucrat (05-26-2023)
