Z06 Makes 640WHP on DynoJet
#81
@Joefab
I watched some of the video again and it looks like the initial run was 608 rwhp. The other 3 runs were in the 630's - 640.
I want to know what happened between the first run where it showed 608 and the other 3 runs.
Was the first run done in 4th gear, and the other runs all done in 5th gear? Something else?
Please explain the initial run that produced 608 rwhp.
Also, if you could post the graph for us all to look at, that would be nice to have. Very hard to get a screen shot from the video.
Honesty and transparency are always appreciated.
PRE-Z06 (12-06-2022)
#82
@Joefab
The following 5 users liked this post by RapidC84B:
Harbgrogan (12-12-2022),
JABCAT (12-06-2022),
JockItch (12-06-2022),
PRE-Z06 (12-06-2022),
ZRacerLE (12-06-2022)
#83
Mopar Jimmy;16059930You guys who know anything about dynos an dyno numbers know that if this car goes to 10 different dynos, at different shops, even on the same day, the different dyno numbers will be all over the place.
CorvetteBrent (12-08-2022)
#84
Received 8,868 Likes
I amended my statement to include Corsa headers and Lingenfelter airbox. So they're claiming 110 hp on an LT2 from those mods.
Just like we're probably going to get some ridiculous claim from just aftermarket exhaust on the Z06.
#86
Received 5,324 Likes
#87
I know you can't be that dense & just like to stir the pot. It clearly says built by Lingenfelter...600 hp... Did Cunningham just make up the number or did Lingenfelter give them the number to advertise?
Corsa most expensive SR C8 system gains 18HP (claimed). Here Fab is already 'whispering' 45HP for starters...
If you want to make the point they are all a bunch of villains go ahead... all I was telling you is that quoting wrong numbers on top of fake numbers does not help the discussion...
#88
Received 2,061 Likes
Love all the bench racers here. Showing absolute disbelief over a 30whp difference between a Mustang Dyno and a Dynojet. This isn't uncommon at all. My C7 read differently on every kind of dyno there was. Always in the same general area, but never expect the same numbers. Mustang dyno's read lower, dynojets read a bit higher. This is common knowlegde in the modifying community.
No, Fabspeed did not spoof the settings for it to read a higher number. They don't care what the stock dyno number is. They are using it to show any potential power gains with their newly developed exhaust system they are R&D'ing. The fact that the baseline run was high is literally meaningless to them so they have 0 reason to engineer a "hero run". To be honest, its probably in their best interest to show lower baseline runs, so they can show their exhaust posting up higher numbers. Not the other way around.
At the end of the day, a dyno is not an exact measurement. It will generate different numbers due to all kinds of different reasons. It's a tool to see power improvements after mods and get a general sense for performance. Cars are going to show a range of whp readings based on many factors so don't read too much into this 30whp difference.
#89
Thanks. Im only reporting what results we are observing and recording on our Dyno jet all wheel drive equipment. To be honest we were shocked and slightly annoyed at the higher than expected power output we consistently recorded run after dyno run. The power is 640 for Mike StreetSpeed717 personal Z06 with a Mike Ward built engine.
So 640hp at the wheels is the number this C8Z06 is laying down and additional significant power gains are being seen and recorded and backed up by consistent dyno runs .
Ive been designing and incrementally dyno developing performance parts for over 25+ years and there are typically power gains from HJS imported high flow 200CPSI cats and free flow exhaust. Always has and always will even under radical high strung high RPM racing style normally aspirated engines like the C8Z06 and 992 GT3 and 718GT4. I own both of the last 2 cars and with HJS cats and free flow emissions legal exhaust added up to 45hp and 35hp to each car with out ECU tuning.
The C8Z06 responded as well to performance parts. The Fabspeed dyno-jet with integrated weather station does not allow input of correction factors to manipulate results like a mustang or other dyno. What’s that mean ? We cant go back into the results and say Airtemp was 90 degrees F when it was actually 60 degrees actual and receive a multiplication/ correction factor to raise power output OR conversely run some other brands performance parts and loose power by inputting correction factors. In addition, fabspeed can not take this baseline Dyno result 640hp and go back into the computer and input “airtemp/ humidity was adverse” and reduce 640 to 620hp lets say …….so future Fabspeed performance systems make even more power.
The next steps at Fabspeed will be working with Helical Great Britain to design stainless steel Inconel carbide electric plug & play exhaust valves that can take extreme heat and survive on a Z06 under all out race conditions. My guys are flying to Charlotte this weekend to drive back another Z07Z06.
Like to design a GT1 rear engine intake scoop in carbon fiber to force feed cold ambient air to the Z06 factory airbox and design exhaust valves to open the shunt exhaust up through the rear decklid for more power and wild sports car sound like McLaren 600lt or Porsche 918 Spyder BUT i dont think guys will want to use a hole-saw to modify their cars.
Should have applied for US Patents for some of the systems I personally designed and were copied by large global OEM manufacturers. If anyone wants to chat offline my email is joe@fabspeed.com and call the facility or be my guest and stop by. Next week we should be putting break-in miles on a GT4RS and then designing parts for that too.
#90
A couple of things to consider. The speed phenom guy is in California with 91 octane gas and street speed had Sonoco 93. Will that make a difference ? I don't know. Also, we have seen them trap in the low 130s on the west coast but what will they trap on the east coast with negative da? Maybe at MIR we will see 134/135 ? Who knows.
#91
The following 6 users liked this post by PRE-Z06:
94Lt1Vette (12-07-2022),
JABCAT (12-07-2022),
jleews6 (12-08-2022),
range96 (12-07-2022),
and 1 others liked this post.
#92
Put it on a large in-ground inertia wheel type dyno and get back to us. Every thread I have read in the past 10 years where the dyno numbers seem too good to be true involve one of these tiny tiny roller, load cell type or hub type dynos. They are excellent for tuning but they definitely aren't as consistent or accurate for final numbers as a large inertia roller dyno.
bufalobob (12-07-2022)
#93
This one particular car posted numbers that were about 50-ish rwhp higher than other similar cars.
However, they ultimately were dummies, because for the chart they posted (..I might have that chart somewhere), it included all the correction factors used. And in this case, it was discovered that the displayed barometric pressure was lower than the most powerful hurricane on record, an impossibility for California - so they were outed by themselves that they were clearly cheating.
Many years later it 'officially' came out that they knowingly cheated by making the dyno think that during the runs, the barometric pressure was much lower than actual, which thru the correction factor, raised the recorded rwhp.
For JoeFab to state that a DynoJet cannot be manipulated to provide lower/higher numbers is IMO, disingenuous to say the least. And especially so for someone who has run dyno's for years.
The following 6 users liked this post by yz250fPilot:
JockItch (12-07-2022),
PRE-Z06 (12-07-2022),
SwanSongZ (12-08-2022),
#94
St. Jude Donor '08-'09-'10
That is not what that means. All it means is that dyno showed that number. There is another video where a dynamic shows a different number. The engine makes 670 hp just as advertised. These engines are SAE certified, they cannot underrated them. So many people don't understand this.
JG853 (12-08-2022)
#96
In the latest video just released yesterday, Mike actually brings up to the Fabspeed crew that a lot of folks questioned the 640rwhp number from the first video, so kudos to him for bringing up the subject. Their explanation was that DCT’s are so efficient nowadays that the often see drivetrain loss of less than 10%
The following 4 users liked this post by JockItch:
#97
The following 4 users liked this post by ZRacerLE:
#98
Still not believeing a <5% drivetrain loss just because it is a DCT when the majority of C8 stingrays are in the ~10% ballpark and they have a similar DCT setup. So that argument does not hold up with that logic.
Either way, the new exhaust sounds awesome from what I can tell in the video and it definitely picked up HP and lost weight. So it is still a good mod regardless of what the dyno is saying HP-wise.
The following 3 users liked this post by ChevyChad:
#99
Yep- just watched his latest video this morning with the results (666 rwhp). So they gained 26 rwhp and claimed to be 30-40 lbs lighter with their setup. I do believe the +26 rwhp and the weight delta. Those are easy and straight forward and legit numbers IMO.
#100
The kid with the red car has carbon wheels to, exact same spec basically, and his car made high 590s then ultimately 608 or 610 I believe they were SAE. The paper on the yellow car video does say SAE in the top right. I personally don't believe it and I think the dyno is reading high. 600-610 is right where a 670 horse DCT car should be.
ChevyChad (12-08-2022),
JockItch (12-14-2022),
PRE-Z06 (12-08-2022),
range96 (12-08-2022)
