LT7 confirmed
#101
The following 2 users liked this post by RedLS6:
CorvettoBrando (11-07-2022),
CPhelps (11-08-2022)
#102
This is what MB can do with 4lt
https://group-media.mercedes-benz.co...l?oid=47663457
M178 LS2achieves 537 kW (730 hp) at 6700-6900 rpm and delivers a maximum torque of 800 Nm at 2000-6000 rpm. Max rpm is 7200.
The article is (IMO) worth the read on the engine part
#103
The article is IMO) worth the read on the emgine part
#104
Received 4,383 Likes
I believe from their 2017 North American Engine plan, GMs original target is 850 HP and 720 lb/ft of torque.
CorvettoBrando (05-05-2023)
#105
The 4.0 MB engine is disadvantaged, in a way, compared to the LT6 dimensions; 720hp at a relatively low 6700rpm, but it has a very small bore with undoubtedly lower cylinder head port flow numbers on the small bore, and it uses 24+ pounds of boost to force the air in.
How much power do you think a boosted 4.1 bore, 7000+rpm LT-6-derived platform would be capable of?
The following 4 users liked this post by RedLS6:
#107
Kodiak Bear (11-12-2022)
#108
#109
SwanSongZ (11-19-2022)
#111
Chevy would use the same basic block, likely just sleeve it for smaller pistons, which may actually make it heavier than the LT6.
RJ-92 (02-02-2023)
#113
That's not how it works... it will be the same Gen6 motor with different bore/stroke combo. The internal displacement will be less. It won't be a new "smaller" motor.
The following 4 users liked this post by RapidC84B:
#114
Could ne the 5.5 lt with turbos but a different use of the FPC, ala the MB 4.0lt , in order to enhance the turbo application.
#115
I noticed this in the recent SavageGeese Corvette video. Watch from 32:30.
The tool the builder uses to hold the crank in place is labeled LT6 / LT7. It stands to reason the crank main journals at a minimum will be common between both engines.
The following 7 users liked this post by Jeff V.:
416vette (02-02-2023),
CorvettoBrando (05-05-2023),
CPhelps (02-02-2023),
PRE-Z06 (02-02-2023),
Ragtop 99 (02-02-2023),
and 2 others liked this post.
#116
^Nice catch. It also implies that the LT7 will be hand built on the same line.
#117
I believe the displacement will stay at 5.5L for the LT7. If not, count me out as a potential buyer.
Unfortunately, the ZR1 will gain weight over the Z06, hopefully marginally.
#118
Great catch in the Savage Geese video. Does this mean the LT7 will be FPC, or could it still be CPC and use the same journal size?
The following 2 users liked this post by RapidC84B:
spooge285 (02-02-2023)
#119
Why does everyone keep going on about a CPC version of this thing? Everything about it is engineered around dealing with the vibration characteristics of the FPC. You can't just drop a different crank in there and call it good.
If they do a DOHC V8 it's going to be very different from this motor.
#120
Received 5,334 Likes
The following 2 users liked this post by JockItch:
user0405240328 (02-02-2023)
