Top speed.. let’s do some math
The equaion we are going to use to calculate top speed is :
vmax = ( 2 · P / (c · D · A) )1/3
P = power in watt
C = drag coefficient
A = frontal area
D = air density, sea level = 1.25 kg/m³
Let’s start with the C7 ZR1 top speed to see how accurate this equation is
P = power in watt on wheels = 660whp = 492000 watt
C = drag coefficient 0.40 (low wing version)
A = frontal area = 2.10 (based on Tadge comment in question and answer section)
vmax = ( 2 · 492000 / (0.40 · 1.25 · 2.15) )1/3
Vmax = 97.2 meter per second = 350 km/h = 215 mph
Official top speed = 212 mph in 2 direction
992 GT3
P = power in watt at wheels = 445 whp = 336000 watt
C = drag coefficient 0.36
A = frontal area = 2.08 (based on Porsche website)
vmax = ( 2 · 336000 / (0.36 · 1.25 · 2.08) )1/3
= 89 meter per second
= 320 kmh = 198 mph
Porsche official website climed 197 mph official top speed
Let’s apply this calculation to estimate the new Z06 top speed
Z07 version
P = power in watt at wheels = 590whp = 440000 watt (assuming 12% drivetrain loss)
C = drag coefficient 0.47 (6% improvement over C7ZR1 Cd 0.50)
A = frontal area = 2.25 (assumption based on narrower previous generation 2.15)
vmax = ( 2 · 440000 / (0.47 · 2.25 · 1.25) )1/3
= 87.3 meter per second
= 314 kmh = 194 mph
Non Z07 version should have Cd around 0.38
vmax = ( 2 · 440000 / (0.38 · 2.25 · 1.25) )1/3
= 93.7 meter per second
= 337 kmh = 208 mph
Z07 = 194 mph
Non Z07 = 208 mph
+\- 2 mph
P = power in watt
A = frontal area
992 GT3
= 320 kmh = 198 mph
Z07 version
= 314 kmh = 194 mph
= 337 kmh = 208 mph
Z07 = 194 mph
Non Z07 = 208 mph
+\- 2 mph
The following 12 users liked this post by Iker:
black2010gs (05-28-2022),
elegant (05-23-2022),
Michael A (05-23-2022),
PRE-Z06 (05-25-2022),
Ragtop 99 (05-26-2022),
and 7 others liked this post.
Popular Reply
05-27-2022, 05:22 PM
Thanks to Iker for starting the discussion; I just incorporated the RWHP data along with the 5-6 shift, and also ran a sensitivity analysis on the coefficient of drag and the frontal area. I used Iker's formula for Vmax as it's part of a well recognized textbook Vmax formula (the rest of the formula considers other parasitic losses).
Some notes; In my simulations the C8Z always attained top speed in 6th gear; the 5-6 shift was not a limitation, when I varied estimated shift points to hit 6th anywhere from 188 to 195mph.
In the top graph, where the lines intersect, is the Top Speed. The bottom graph shows the variation of this intersection as parameters are varied.
Also, this isn't necessarily an accurate prediction, this is just fun with math for now as it contains assumptions and error bands.
Of course, these equations assume the engine speed is at the horsepower peak, and that coincides with the top speed of the car. Based on the gear ratios published on another thread, that's not lining up with the speeds above. So the +/- 2 mph error band is way over optimistic.
However, let's keep working in it. Is there a horsepower curve published for the Z06 engine?
Michael A (05-24-2022)
P = power in watt
A = frontal area
992 GT3
= 320 kmh = 198 mph
Z07 version
= 314 kmh = 194 mph
= 337 kmh = 208 mph
Z07 = 194 mph
Non Z07 = 208 mph
+\- 2 mph
P = power in watt
A = frontal area
992 GT3
= 320 kmh = 198 mph
Z07 version
= 314 kmh = 194 mph
= 337 kmh = 208 mph
Z07 = 194 mph
Non Z07 = 208 mph
+\- 2 mph
vettesweetnos (05-24-2022)
P = power in watt
A = frontal area
992 GT3
= 320 kmh = 198 mph
Z07 version
= 314 kmh = 194 mph
= 337 kmh = 208 mph
Z07 = 194 mph
Non Z07 = 208 mph
+\- 2 mph
P = power in watt
A = frontal area
992 GT3
= 320 kmh = 198 mph
Z07 version
= 314 kmh = 194 mph
= 337 kmh = 208 mph
Z07 = 194 mph
Non Z07 = 208 mph
+\- 2 mph
Excellent method to extrapolate top speeds. I am just adding Coefficient of drags numbers referenced in SAE and Tadge as well as official verified speed for the base C8 (non Z51).
Basically coming to this more from an empirical/observation angle and bottom up instead of top down. .
Also the assumption here is that when it comes down to top speed the advertised or video documented numbers from all manufactures reference the most sleek and less down force impaired version of the car.
Posting C8 Z51 Cd to extrapolate base Z06 Cd (historically close)
SAE/Tadge Cd numbers for C8 so far: https://www.sae.org/news/2020/03/eng...e-architecture
Top speed C8 non Z51 (490 SAE HP) = 194 (averaged on 2 runs)
Watch The New Corvette C8 Do 194 MPH In Top Speed Run (motor1.com)
Base (top speed) C8 Z06 with 180 more SAE HP and Cd extrapolated from above of 0.34-0.36 and verified C8 base 194 = 210 MPH.
It seems we are extrapolating very close numbers.
The following 5 users liked this post by Telepierre:
elegant (05-25-2022),
Michael A (05-24-2022),
skank (05-24-2022),
vettesweetnos (05-24-2022),
ZRacerLE (05-24-2022)
I have extrapolated these numbers and come up with the following calculations....the "6x6x6 Rule"
6 mos loss of license
6 mos additional probation (and collecting litter on the fine roads down here in Camelot)
$6K surcharge on my Insurance...
See, if you do the math it all works out...
Theoretical top speed however how long to get to vmax? 10 miles? 100 miles?
Received 2,069 Likes
Telepierre (05-28-2022)
The following 7 users liked this post by RedLS6:
Iker (05-28-2022),
Michael A (05-28-2022),
PRE-Z06 (05-27-2022),
Ragtop 99 (05-27-2022),
Telepierre (05-28-2022),
and 2 others liked this post.
I
A more accurate way is to take the HP loss of a similar drivetrain like the base C8/Z51/LT2 and use the total HP loss with a few minor considerations, basically treat it as a constant loss plus or minus. Going through the C8 Tech forum, I found a post from a tuner stating he sees an average of 442 RWHP from the Z51 cars giving us a loss of 53 HP. The higher RPM of the LT6 will give more loss to churn/windage but not by a lot as the dry sump does its job. Another area is the sweep rate of the Dyno, the typical is 250 RPM/second which causes losses due to overcoming rotational inertia losses. While approaching top speed, the “sweep rate” is approaching zero also which means we can back out the HP loss due to rotational inertia. It’s not a lot to begin with due to the FPC of the LT6 and no driveshaft so I would call the small decrease a wash with the small increase in churn/windage.
Can you run the graphs again using 53 HP loss for a maximum of 617 RWHP? It looks like it may come out close to the OP calculated 208 MPH.
There goes the theory?
Flat plane 2023 Chevrolet Corvette Z06 revealed (sae.org)
Ready to rip, LT6 delivers remarkable 670 net (per SAE Standard J1349) horsepower at 8400 rpm. The redline is 8600 rpm, while the torque curve peaks with 460 lb-ft (623 Nm) at 6300 rpm. The super-short stroke minimizes the crank’s rotating inertia, expediting the rush to the redline. Though executive chief engineer Tadge Juechter insists Z06 is not a “numbers” car – its official GM-listed top speed is actually slightly slower than that of the conventional Stingray – he does tout a 2.6-second 0-60 mph time.
Edit: which means the cD/frontal area are magnitudes (non linear) above base C8.....?
Not necessarily, it appears from reading the article that Tadge was talking about the Z07 equipped Z06. There was an interview/reveal where a GM rep (can’t remember who) stated the regular Z06 will slot between the C7Z and C7ZR which puts it between 205 and 212…right where the above calculations show.
The following 2 users liked this post by smithers:
Telepierre (05-31-2022),
WalterSobchak (05-28-2022)
A more accurate way is to take the HP loss of a similar drivetrain like the base C8/Z51/LT2 and use the total HP loss with a few minor considerations, basically treat it as a constant loss plus or minus. Going through the C8 Tech forum, I found a post from a tuner stating he sees an average of 442 RWHP from the Z51 cars giving us a loss of 53 HP. The higher RPM of the LT6 will give more loss to churn/windage but not by a lot as the dry sump does its job. Another area is the sweep rate of the Dyno, the typical is 250 RPM/second which causes losses due to overcoming rotational inertia losses. While approaching top speed, the “sweep rate” is approaching zero .......
corrected a typo as well, frontal area in the graph was 2.2 and not 2.25. One takeaway here is that we're really sensitive to area and drag coeff when counting MPH's, small changes make large differences. If you move the 5-6 shift to the low-mid 190's to account for any error in tire diameter I may have, the top speed difference isn't dramatically different, there may be a MPH or so here.
The following 2 users liked this post by WalterSobchak:
SharkDiverZ06 (05-29-2022),
Do you have any idea how can we calculate the acceleration time from 0-186 mph and 1/4 mile trap speed for the base car?
