C8 Z07 Front Splitter and other aero parts or Not?
Hi Corvette Enthusiasts,
I had the base 2020 C8 without the front splitter and other aero pieces. Using the front end lift system and front cameras, I was able to avoid almost all of the scrapes to the front and bottom front end of the car. It wasn't hard to drive around and keep the C8 body from damage.
Now, I want to go bonkers and order the whole carbon fiber (or carbon flash) package offered for the Z07, only not the carbon fiber wheels. This includes the carbon fiber (or carbon flash) high wing. I think the aero pieces really make the Z06 look great by the way.
I do not race my C8 so the aero pieces are really more for show. So, to those with experience with these beautiful aero pieces on the C8, would you order these pieces again? Or are they just too easy to bump and scrape? Have you had to replace your aero pieces?
Or, do you believe the aero pieces add so much to the car that you would prefer to have them and just be careful on how you drive the car? I can also leave them out and the car still looks marvelous with the new low spoiler and I think the front end looks ok without the splitters having the advantage of higher ground clearance.
Maybe buying the carbon flash aero pieces rather then the carbon fiber might be a good ideal as I might save money in the long run as I may need to replace the front splitter some day due to damage?
Do you prefer carbon fiber to carbon flash aero pieces? Why?
Thank you for the benefit of your experience,
Luc
Luc
Received 8,898 Likes
While not on a C8, my C6 Carbon Edition Z06 has all the carbon fiber aero from the ZR1 & sits a good bit lower than a C8. I rarely, if ever, scrape my splitter or side skirts on anything. For reference my front splitter sits 3.25” off the ground.
The C8 Z06 will be available with front lift, so you should have no worries.
I'm on my 3rd C8, the only thing to ever scrape is the plastic air diverter hump that is in front of each wheel. All 3 been Z51, none have had front lift. The splitter has never scraped. I intend to order Z07 w/o front end lift and I'm not worried. I plan to order carbon flash aero as I have a price target with the car and I think exposed CF will be a big upcharge and the C7 ZR1 has had issues with bad supply and carbon parts yellowing.
lucative - Like you, I think the Z07 aero pieces look awesome on the new Z06. I plan on getting them. I'll be getting the front-end lift and then likely lowering the car, figuring the 1.6" of lift will more than offset the ~0.75" I'll drop the car. I think the front will be fine but I fear lowering it will cause the side and possibly (?) rear of the car to scrape since they don't lift. For reference, though I realize it's apples-to-oranges, I have a C7 Z06 with the Z07 packages and don't have any major issues. I definitely pay attention to driveways and whatnot. And sometimes the front splitter scrapes, but it's usually the bottom and so not visible. I have to be careful about curbs since pulling forward into one would definitely crack it. I contemplated dropping my car but there are times when pulling out of driveways where having the extra 0.5-0.75" made a big difference. FYI, I live in LA. If you live in somewhere less dense and flatter, then I'm guessing you'll have less of an issue.
No Z07 pkg for me b/c not tracking it & can use that $ on the options I really want
