LT6 Intake Manifold
LT6 Intake Manifold
Short SAE blurb describing Z06 LT6 intake manifold:
The I/O Buffer Information Specification (IBIS) Open Forum Releases the IBIS Version 7.1 Specification (sae.org)
The following 3 users liked this post by 235265283...:
Gee, I would have thought they would have actually explained what was going on dynamically with the entire induction system, being an SAE write up.
It would be nice to see all the math involved. Maybe GM will allow someone to disclose this technical information for all you techies some day.
Zaro Tundov (01-14-2022)
IMO, the basic principles colorfully referred to in this blurb have been known (and applied to various extents) for a long time. For example, a relatively easy-to-read book with some math (but no CFD stuff) that explains these principles is; Scientific Design of Exhaust and Intake Systems, by Philip Smith, Robert Bentley 1962
An even better book that goes into all the detail was written by Gordon Blair in 1999. "The Design and Simulation of 4 Stroke engines". If you are an SAE member you can get a discount on it.
The real trick isn't the trumpets that dictate the single cylinder induction frequency, that is pretty straight forward, however they are are canted to reduce cross talk but the controlling of the multi cylinder induction frequency is where it gets really interesting. Maybe they will allow the sharing of the CFD data of the plenums and valving some day.
smoove7410 (01-13-2022)
Kinda disappointed in this statement:
"Let the record show that the LT6 is the most powerful naturally aspirated V8 ever produced."
Doesn't GM have an even more powerful V8 crate option? And there are some other aftermarket options as well. Maybe semantics, but "the LT6 is the most powerful naturally aspirated V8 ever put in a factory production car" seems more accurate.
Yes, SAE doesn't care about aftermarket, but they are known to be pretty particular about accuracy so I think my comment applies.
ZRacerLE (01-13-2022)
The following 3 users liked this post by Katech_Mike:
Again, my point is the statement as made is NOT accurate because they left the details out.
If you want to assume they meant something else (which they probably did), that's on you. But I hold SAE to a higher standard than CNN/MSNBC/Foxnews/etc.
BTW, your example seems to be wrong.
5.5L engine in the Z06. Assuming it is exactly 5.5L, that's 335.631ci. Take the 670 and divide by 335.631 I get 1.99hp/ci. So, close enough to your 2.01.
BUT
458's engine is 4.5L, 562hp. Take 562 and divide by 247.607 (actual cc is 247.4, but the bigger number actually lowers the hp/ci) and you get 2.269hp/ci.
So I'm not following how the LT6 is the highest HP per cubic inch NA V8.... I think they really meant the highest output NA V8 and left out the "factory production car engine" part.
fzust (01-14-2022)
The Consigliere
Received 5,458 Likes
Yea well the production part was pretty well implied, I mean it was said at the original release of the engine in the car, so.... I guess its winter and people need to debate over something... next big news is still a few months away.
The Consigliere
I was disappointed when I got the newsletter from SAE with that article, as it revealed nothing new about the induction system than what had been published/disclosed before. As said above, no math, no numbers, no charts.
The following 2 users liked this post by RedLS6:
ArmchairArchitect (01-14-2022),
The article said "production engine", no mention about "production car". I'm really just picking on SAE here, they are usually known for being very precise (hey, its what they do) when they say something. Do I know what they mean? Of course. Does it still disappoint? I surely hope that SAE isn't going to drop into the shoddy traits of mainstream media.
OnPoint (01-14-2022)
