Mismatched tire sizes" ESC, TC, ABS issues?
Mismatched tire sizes: ESC, TC, ABS issues?
Hello,
I tried searching but couldn't find a thread on this. I bought a set of Nankang CR-S V2 in 265/30/19 and 325/30/20 as those were the closest sizes I could source. I figured that 20mm extra width wouldn't hurt but misread the diameters when I was looking at different sizes (265/35/19 was OOS). The original stagger had a 5% R/F differential. This set will have a 9% R/F differential. Will this cause problems with the ESC, TC or ABS systems? If so, how do I disable those warnings?
Thanks,
Chris
Thanks,
Chris
Sr.Random input generator
No, I don't think it would create any issue. It gets a bit sensitive if you use the same diameter front and rear, but even that is more of an issue in regular modes like Touring, etc. Since your setup is the other way around, I don't see it causing issues.
Back in the day of C6 Corvettes, this was a bigger issue, but since C7s, the system has become quite a bit more tolerant.
X25 (03-27-2024)
I have this combo and i get traction interference. you still need to workout the math or turn everything off
Front Tire Size: 275/35-18 Rear Tire Size: 335/30-18
CAINCA (03-27-2024)
I ran the car for the first time at Laguna Seca on Saturday. I ran in Track mode in PTM Sport 1. I didn't have any issues with traction control or ABS the entire day.
