HEADERS….. who’s are best? No drone
I’m looking for a bit of exhaust sound change. A bit louder but I don’t want the drone that comes with changing the mufflers and cats. Thought maybe doing headers would give me the sound I need without the headache of drone during long drives. Has anyone changed just their headers and kept the stock mufflers? How do you like it? Who did you go with?
c8professional (03-13-2024)
I live in an area that doesn’t have e check. So I could get away with no cats. Would that be a bad thing for throwing codes and drone?
so you’re saying hi flow cats and headers gave you a good sound and no drone inside?
Correct regarding headers + cats. Here's my thread on the two: https://www.corvetteforum.com/forums...port-cats.html
MikeinAZ (03-15-2024)
Supporting Vendor
Adding headers or sport cats will add drone in cabin in loud mode if you currently have a dual mode exhaust.
If a customer of mine is worried about drone I always point them to a top of the line C8 Corvette Corsa catback with the four valves as they tend to minimize drone better than any other option out there. If you do not have the z51 package or the performance exhaust package from the factory you cannot run this setup.
If you don't want to spend the big bucks on a new catback sport cats or headers will be a good option at a much lower price point. On an oem dual mode setup once you close the valve it'll be super tame.
Happy to go over all the options in stock from headers sport cats & catbacks with special corvetteforum savings.
__________________
http://www.corvetteexhaustsystems.com
845-476-8881
sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
845-476-8881
The following 3 users liked this post by Corvetteexhaustsystems:
Supporting Vendor
I would start off with Corsa Sport cats and see how you like that, then you can add headers or an exhaust from there for more power and sound.
We have these in stock and can help you start off there.
-Josh
-Josh
Hoffy (02-06-2024)
Supporting Vendor
thanks for the information. I do not have the Z 51 package. So mine is just the base model entry level exhaust. No valves to control. I figured doing at least the high flow cats would give me more sound. But the stock muffler would hopefully keep it tight enough tonight give me crazy drone.
If you want to add volume without modifying emissions components, I'd suggest headers. I do have the following options in stock ready to ship:
Corsa Headers For C8 Stingray
aFe C8 Twisted Steel Headers For C8 Stingray - Raw Finish
If you would want to go with a Sport Cat, I have the following options in stock:
Corsa Sport Cats For C8 Corvette (for the month of February I can get you $193 back on these)
Kooks Ultra Green Cats For C8 Corvette (these utilize a custom-spec GESI catalytic converter)
Supporting Vendor
You can probably pick up an NPP exhaust (C8 performance exhaust) for $100 or so and bolt that on. Valves remain open without the wiring. Easy and inexpensive first step to make it louder. I ran my C7 with valves open all the time. I've already bought one myself, just need to bolt it on.
Movie Muscle (02-18-2024)
St. Jude Donor '19
I'm thinking of just adding headers with the stock NPP hoping for a more aggressive sound, but you're saying it barely increases the exhaust sound? Bummer! I do have 2M Sport Cats, but from my research, they don't really add anything other than sound, so I'm not sure I will use them. I'm worried it will be too loud with the headers and sport cats.
C7Me (02-12-2024)
