PDR and Autocross
PDR and Autocross
Has anyone SUCCESSFULLY used the autocross function in the PDR and had it set the start and stop points correctly? Set the start and finish according to the manual... If I don't start the record manually, it doesn't automatically start at the start point. Then I get varying video lengths and can't compare runs. Which brings me to the next issue....would need to manually offset the start to get the times right.
I honestly don’t think the functionality is there. They need to add the ability to insert start and finish while synching video, that would solve a lot of the issues. Also have the start time base on accents from a stop at the start gps point so the recording time is irrelevant.
Pro Mechanic
It doesnt automatically start timer at the set start line and then stop for lap time at set finish line if you start recording before you stage? This is how it works on a closed circuit course. it starts timer as soon as you cross start finish line you set and then resets each time you cross the line. If you go out on track past the start finish line it doesnt start timer until second lap.
I think ultimately the issue with autocross…. Is your at the start line physically (gps location), but haven’t started the run until you are “released” by the starter, then the timer starts a few feet from where you stage. So they need logic to start the run based on location AND another factor such are speed movement or accel is higher than’x’ if that makes sense.
When you do this, does the record automatically start when you cross the start point, or do you manually have to start recording before they release you for the run? The parade lap is great, but we don't get that... however if the concept holds true, I can work around it. Our local SCCA has the timer start about 15' ish away from the release point....so it should be far enough to NOT trigger a "start line" if setup that way....kind of have to lose a little bit on the first run to make sure its set correctly but the first run is rarely the best run anyway.
I have a Racebox mini, but trying to avoid putting extra crap in the car...no great place to do a windshield mount that is completely out of the way, etc... The PDR SHOULD be able to handle this task with some pretty simple coding upgrades to detect a launch from a stop in auto cross OR allow the software to reset the start and finish through editing the results.
