ProCharger is adding variable launch RPM
Pretty cool feature being added to the ProCharger setup. I'm guessing this will be available for HP tuners as well in the future.
New feature being added to the ProCharger C8 supercharger systems.
- User defined launch RPM!
Facebook Post
PhoenixM3 (08-04-2023)
https://www.facebook.com/562317422/v...2696068781022/
He removed the post. He must have jumped the gun on releasing the feature. He did show its functionality and was able to launch at 2500 RPM vs 3500RPM
This would be an HP Tuners feature. Not a Procharger's specific feature.
Why would the ECU care what power adder or modifications are done to the engine to change launch RPM?
Of course this is an ECM feature but ProCharger is not using HP Tuners. This feature was added by ProChargers tuners.
Unfortunately, GM doesn’t use the term “launch control” to really define it, but I’d imagine HPT can locate the necessary tables.
But... is it dynamically adjustable like the Z06? Or need to plug in HpT and have laptop etc
He said it can be controlled and adjusted to any RPM setting via steering wheel controls (I'm guessing the range is set in the ECM or TCM)
So he says there are normally two launch rpms? 1700 and 3500 rpm? I've only seen the 3500. How do you get the 1700 rpm mode?
Just press the brake pedal firmly not hard and will commence the low rpm. I did this at the track by mistake and ended up with a much higher ET.
would be exceptional if its via steering wheel controls under the performance menu.
