Intake manifold removal.. any videos?
I’m going to change my intake and throttle body with ported units. I’ve been trying to find a video of the removal. I’m not to worried about the bolts but the clips is really what I need assistance with.
any videos out there?
thanks guys
thanks guys
SUPER simple job with basic hand tools. No video needed, I promise. All you'll need is a basic socket set, a flat blade screwdriver, and your hands. I would suggest some blue Loctite for reassembly.
Madsen (06-01-2022)
Here's a thread with likely most the details you need:
https://www.corvetteforum.com/forums...-manifold.html
Madsen (06-01-2022)
Madsen (06-01-2022)
It’s a bit more challenging with the HTC over the Coupe.
You’ll end up working back and forth between the trunk and engine cover, have to detach the coolant overflow, and just generally squeeze into a slightly smaller space.
That said, it’s not that hard, just be patient and document what you’re disconnecting, so that you get it back the same way.
Madsen (06-01-2022)
