C8 trans fluid change only 8 quarts?
It's not cheap but if doing fill yourself you want this ..
https://www.summitracing.com/parts/ado-10-4130
Racer86 (08-13-2023)
So far I've noticed that they take just under 11 bottles total (non -track fill) when changing the fluid and filter cartridge at the same time. Usually when you fill it to the fill plug hole, then start it and run through the gears it will take about another 3/4 of a bottle.
Check out this link from Tech Link I think it will answer your question
https://gm-techlink.com/?p=15781
Must be wrong link. He asked about fluid capacity for fill. You linked something else
As an update I have done the change 3 times now. It takes 8.5 quarts to fill with only the canister filter change. I add the extra 2 quarts after for track use. The latest change I had done at the dealer to get the transmission flush procedure that had been added as a new service in the past year or so. The dealer added 8.5 quarts to get to the fill line after the procedure so it is always the same result with only the canister filter change.
The following 3 users liked this post by March:
E-Ray, 3LZ, ZER, LIFT
Received 9,651 Likes
I watched the screen which didn't say anything significant other than some like test in progress. There was a ball going back in forth on the bottom to let you know it was working. RPM stayed at 2000 rpm in Neutral. At the end, as year one said flush copeted.
RE Thread title took bit over 9 quarts (actually Liters; 9 Liters = 9.5 quarts) with car on a lift.
BTW a filter change is NOT required for the 3 years REQUIRED fluid change. But I had my filter changed at year ne on GM's dime with ~3000 miles so had to have it done as required at 7500 miles.
Andybump (08-11-2023)
#33
TIA, and have a good one,
Mike
#34
My '23 C8 Stingray is at my dealership here in Phoenix right now. It is one year old with 3300 miles. My service advisor told me you can get your free oil, filter & DCT filter replaced any time as long as it's before 7,500 miles. Going forward the DCT filter should be replaced at every third oil change. End of conversation.
#35
JerryU (10-11-2023)
#36
If you put 7500 miles/year on your car and don't drive in a manner that makes your OLM come on sooner then yes. But many, if not most, C8 owners will have their OLM indicate the oil needs to be changed in one year even though they have put fewer than 7500 miles on their car. It may work for him but it wouldn't work for me. And if his first year mileage is indicative of what he will be doing annually it won't work for him either. Perhaps he meant to say that the DCT fluid should be changed every third oil change and he always plans on changing the DCT filter every time he gets the fluid changed (which isn't required).
#38
Sounds like blukey's dealer figured out a way to pad his bottom line doing unnecessary DCT filter changes.
#39
DCT maint
If extra transmission fluid is added GM says it does not have to be removed.
I did an early oil change (best thing u can do for your engine) and the transmission filter change on my dime to remove any early particulates
I added the 2 extra quarts and feel the car shifts smother and quieter
GM requires a transmission filter change at 7500 miles even if done early. The oil and filter change must be done together if GM is paying
If the fluid is 3 years old GM requires a transmission flush of fluid and filer; about $1200.
As part of the Book labor is 3.5 hours
A transmission filter change should run about $300-$500 depending on dealer markups and larbor costs.
My understanding is in the 2024 user manual their is a statement for any transmission issues GM will look at service records to see if prescribed maintenance was performed.
With Engine running the GM Service Computer is operating the DCT valves (Andybump identified over 14) in a sequence that gets any debris washed into the filter housing. When the filter is removed it and the ~8 oz of fluid in the filter housing held whatever the "flush" dialoged is removed. Minimum every 3 years all DCT fluid has to be replaced but not with the filter change flush!
DCT filter and fluid changes should be done per the manual maintenance schedule and not that a transmission filter change is required every 3 rd oil change. Some change oil only once a year and others more frequently
#40
Everything is about right BUT:
Yep need to change the DCT Fluid min every 3 years BUT not the filter! The filter change requirement stands by itself. Aflush is only attached to a filter change NOT the 3 year fluid change. It is not related to the every 3 year minimum DCT fluid change,
Now I took advantage of the FREE DCT Filter (with flush) and engine oil change year one with ~3000 miles. I knew I would not have 7500 miles end year 2 and foolish to take advantage of the FREE service end year 2 with ~5500/6000 miles just to get free. Then ~1500 miles change the DCT filter again! Plus most DCT wear occurred in that at 3000 miles so got most out year 1.
So in my case year 3 had all DCT Fluid chnaged (with required flush) a new DCT filter and engine oil and filter change using Mobil Supercar oil.
My bill was $991 for all the above!
zcobra1 (01-15-2024)
