Porting throttle body or intake manifold?
sidewinder77 (02-28-2022)
Popular Reply
09-17-2021, 09:59 PM
Full disclosure: I'm a terrible photographer!
Once again Ruben @ SoCal Porting has absolutely knocked it out of the park; this thing is beautiful and easily the nicest LT1 or LT2 ported intake manifold I've ever laid my hands on (I tried 3 different ones on my C7 alone). I would say in addition to the inlet of course, the 8 runners were all 95% touched with manufacturing flaws removed and seams & joints smoothed. If anyone would like additional or specific pictures, please let me know I'm quite excited to get this and my Soler ported throttle body bolted on, to say the least! If anyone needs some IM/TB cores let me know.
@MillerTimeISU @Atlantan
Soler sells a ported TB for the LT2 and Wilson has a ported LT2 IM. Both are on my "wishlist" once my C8 arrives.
Both mods performed well on my C7!
mzbrooks (01-23-2024)
Yes I have ported both. The gains are about what other LT powered cars have shown so you're looking at about 10-15 hp, it may not sound like much for the money spent but if you look at it from the perspective that tuning will not become available anytime soon, then you don't have many options.
The 1 7/8 AR Headers have been the biggest bang for the buck in returns on improved power, they showed 17 peak hp but up to 34 under the curve. Those 3 mods alone will put a gap against a stock c8, assuming traction isn't an issue.
jimbob8915 (01-14-2021)
Supporting Vendor
We have had the modified and ported C8 TB out for a while now! Check out our store. Same performance/features as our LT1/LT4 TB. We have to update the pictures on our site since we have done a few updates since then but lots of C8's already using it (looks more like the LT4 TB).
We have a 91mm (from $275, no tune required) and a 100mm (from $335, requires tune, adapter included). Add a controller ($95) in any case for a complete throttle control solution.
If you have ported your manifold we'll match either the TB or the Adapter (if required) to meet your porting on the manifold, this is also complementary, please coordinate with us before ordering.
No other modification will change your car so much for so little, so easily, and warranty safe.
Cheers!
Cheers!
Kracka (01-14-2021)
Cheers!
Cheers!
Since the C8 ECM hasnt been cracked or is able to be tuned I would think that means any of yours or any other companies TB that requires a tune would not work on the C8 then currently.
racerx8 (06-01-2022)
Location: North/Central NJ - a.k.a. Gotti in the CFNE section
Received 1,562 Likes
St. Jude Donor '05
Can you explain the benefit and what you noticed on a N/A C8 with the DCT trans (which is far superior to the A8).
Thanks,
Mike
Supporting Vendor
I added a ported TB on my c7 z06 A8 and it helped driveability a good amount do to the lag on the pedal and also because I think due to it being S/C.
Thanks,
Mike
Thanks,
Mike
All our C8/DCT customers love it.
Thanks,
Went with the 95mm Throttle Body Matching by Gwatney Performance, another excellent company. No codes and no tuning required.
As stated, easy 15 HP at not a lot of cost. Great Mod for the C8.
Looking at their site i cant find that ... is that that katech 95mm throttle body that Gwatney has? Or did you buy the whole kit with ported intake manifold with a 95mm TB?
any issues with your set up.. did you happen to Dyno this set up to confirm results?
HeadTurner (01-19-2021)
