Drilled and slotted rotors for C8 yet?
I am wondering if there will be or are there already drilled and slotted brake rotors avialble for the C8 that will work with the calipers already there and then just upgrade the pads to achieve a better braking experiance?
The following 3 users liked this post by MitchAlsup:
StickerDick (05-04-2020)
At COTA last year, I attended the Cadillac Performance School. There was a Brembo rep there and the question came up about why the CTS-V and ATS-V didn't have drilled or slotted rotors. He said there were not necessary.
My guess is the pad material does not outgas enough to warrant them.
Received 7,755 Likes
CORVETTE TODAY Host
St. Jude Donor'15
You'll have to get them aftermarket....thank you ZIP Corvette.
StickerDick (05-05-2020)
The following 7 users liked this post by BrunoTheMellow:
gthal (05-10-2020),
JerryU (05-06-2020),
juanvaldez (05-06-2020),
Krusty84 (05-14-2020),
Racer86 (05-18-2020),
and 2 others liked this post.
Next we need tow hooks painted red and mud flaps.
Get proper 2-piece slotted rotors from Essex when they're available. Don't waste your time with solid drilled aftermarket garbage.
The following 5 users liked this post by RapidC84B:
breakskeet (05-08-2020),
Newton06 (05-09-2020),
Shaka (05-07-2020),
StickerDick (05-05-2020),
thebishman (05-06-2020)
On a modern designed and built rotor using quality material this isnt always the case. I ran Brembo drilled rotors on my old 4th gen F-body for years and never had a crack form. If this was the case and was true you wouldnt see $100k+ or more performance cars with drilled rotors on them from the factory (IE Porsche, Lamborghini and Ferrari) and even GM's own Corvettes used drilled rotors when it came to the ceramic options. There are still several race events I have seen on TV where race cars are still running drilled or slotted or drilled/slotted rotors.
Platinum Supporting Vendor
Thanks for calling our rotors junk, have you ever seen a set of them? I will put them up to Brembo's any day.The rotors coming from Essex will be AP, great product but who is putting the holes in them?
I agree but it is because most drilled rotors are cosmetic. Our rotors that are drilled are cosmetic as well but I we have raced on them when we had to. Our holes are like the Porsche where they have a fillet cut around the hole so there is no where for a crack to start. This is how Porsche does it, I have also heard the holes on the Porsche rotor were cast as well but I do not know that for sure. We use a iron rotor made in the USA. I have never had a drilled rotor come back for a crack because it was drilled.
I ran a two part brake rotor system on my SlingShot as well as my Mini Cooper, I know that is not a Corvette, but we did track days with both of them, and never had any issues with those type of rotors, and they were both drilled setups.... may have been for cosmetics, I don't know, All I know is that they worked better than stock, and I was happy using them at my driving level. And I guess in the long run, that is all that matters to me. So, if Zip makes a rotor that I can afford and works on the C8, I'll buy that... if not, I'll get the best product I can afford to work with my style of driving and with the look I'm wanting as well.
The following 3 users liked this post by bobgolub@hotmail.com:
Wasn't calling your rotors junk.... I'm calling drilled rotors junk. They create stress risers and crack. A quality 2-part floating rotor is the best setup for longevity. Surprised you would sell drilled rotors with your racing background. I had good success racing ST2 with DBA rotors, but they're not floating. Building a new setup I'd get a proper floating 2-part.
StickerDick (05-07-2020)
E-Ray, 3LZ, ZER, LIFT
Received 9,647 Likes
