Z51 enhanced cooling
What does the enhanced cooling of the Z51 package include?
On my C6 Z51 (m6), GM put an external oil cooler, without a thermostatic control. The result is the oil takes forever to warm up in cold weather. If there is external oil cooling on the C8, has GM cured that short that design shortfall?
Received 2,061 Likes
The additional C8 Z51 radiator cools the engine coolant after it passes through the front mounted radiators. Tadge stated that the additional (3rd) Z51 radiator "super cools" the coolant (gets the coolant closer to ambient temp). The "super cooled" coolant then flows through another water to oil heat exchanger that cools the DCT (DCT and LSD/ELSD share oil, so it cools both). I guess they realized they needed the extra cooling for the DCT/LSD when driven hard while they were testing/developing the C8.
The LT2 uses the same type of oil to water heat exchanger that the late C6/Dry sump engines used and the C7 Dry sump engines used. So oil warm up will not be an issue. I thing the driving factor for GMs change to oil to water oil cooling was to improve gas mileage on cold starts.
The following 2 users liked this post by CGZO6:
purple heart (03-18-2020),
rponfick (01-24-2020)
Had an 09 Z06 that had the external (air to oil) oil cooler, had to cover it in the winter to get the oil up to temp. In 2010 (if memory is correct) GM changed the oil cooler to a water (coolant) to oil heat exchanger. It uses engine coolant exiting the block (hot) to warm the oil faster on cold startup. It would also keep the oil from getting too hot when driven at 7/10ths, but wasn't very good at keeping the C7Z06 oil temp low enough when tracked on a road course on a hot day.
I've thought wrapping my cooler for the winter too.
I forgot about the cooling needs for the transmission. what's the ideal temp for a DCT? I put an external cooler on my Camaro when I put a high stall in it. IIRC, the ideal temp (160 - 180*) was much lower than ideal engine oil .
FB1 (01-03-2020)
The third radiator on the Z51 is used to cool the transaxle and eLSD. Per a GM seminar at Carlisle, the coolant from the front radiators is branched off before reaching the engine, to the 3rd radiator, which feeds the transaxle, and is then routed back through the main coolant system. The 3rd radiator doesn't directly cool the engine at all, but by off-loading the heat from the transaxle to a third radiator it keeps the coolant the engine sees cooler.
extra fan
I saw online somewhere.
A Chevy engineer was talking about have a extra fan behind the driver's side vent for cars going to the middle east.
Does anyone have any more information about this extra cooling?
Thought it would be a good idea since AZ & NV are just as hot.
E-Ray, 3LZ, ZER, LIFT
Received 9,650 Likes
Z51 added Liquid/Air heat exchanger. Coolant from front rads gets extra cool and goes to DCT Heat Exchanger and Engine:
Liquid/Liquid DCT Heat Exchanger
LT2 Liquid Engine Coolant/Liquid Engine Oil Heat Exchanger- Similar to LT1 BUT Larger
To the OP the Z51 adds a 3rd radiator in the passenger side intake... it's in series with the other two.
JerryU (01-14-2020)
I know that GM does a lot of testing In hot climates. My concern is that all of hot weather testing was done in low humidity environments. They also should have tested in high heat and high humidity conditions like South Florida (Sebring Race Track) in June through August. I asked Chevy engineers about this after the C7’s started showing their over heating problems. They told me that they did not test in high heat / high humidity 98 degrees and 95% humidity conditions. There were early pictures of the C8-R testing at Sebring at night but I did not see regular C8 testing down in South Florida.
When I caught up with him Saturday he had an answer: “No the production car had not been tested at Sebring summer DE conditions, but based on other testing that has been done it is believed that the car can handle the conditions outlined”.
Wait, what? Humid air has greater heat capacity than dry air.
Water has way higher heat capacity, humid air contains more water than dry air; Thus humid air will cool or heat faster (exchange will be faster).
Engine oil has around 215-220*F, so 110*F in Florida anyway will be cooling. 110*F dry is, in theory, worse than 110*F humid, but in reality while car is going 100mph or more, heat exchange is so fast that this ~2% of heat capacity difference (dry vs humid) doesn't matter.
And point about lower amount of oxygen in humid air is valid, so as it was pointed, in theory, combustion will be calmer...
https://www.electronics-cooling.com/...-of-moist-air/
C8C (01-31-2020)
Banned Scam/Spammer
Lots of cooling. These are some pics:
Yep, when looking at the weight of the DCT versus the C7 M7 have to remember the M7 Trans cooler was a separate air to fluid cooler with a fan and the eLSD hydrilic pump included an electric motor with valves, hoses etc all separate from the Trans. With the DCT it's all together. That liquid/liquid heat exchanger is also more efficient than air/liquid.
Someone pointed out that the Z51 extra air/fluid cooler is on the other side of the car and what I showed was just the fan blowing air through the hot engine compartment when it gets too hot.
Banned Scam/Spammer
I love those cut away views of engines, transmissions, etc. Kinda like looking at a detailed map, the closer you look the more you see and learn.
JerryU (02-01-2020)
