DCT Fluid cost
Check out Summit Racing, they have free shipping (and often have discount coupons) if you spend enough.
$24 on RockAuto; Google for a 5% off promo code.
https://www.rockauto.com/en/moreinfo.php?pk=12870237
The following 2 users liked this post by Kracka:
Ron_Attleboro_MA (04-21-2024),
V Vette (04-21-2024)
I'll personally be running Redline DCTF once my powertrain warranty is up:
https://www.summitracing.com/parts/red-31004
All DCTs are not the same. The fluid designed for one may be completely wrong for a different type. Before switching to something other than what GM recommends, I'd suggest checking with the manufacturer of the fluid to make sure they say it's compatible with the Tremec unit.
The following 4 users liked this post by Red Mist Rulz:
how many quarts do we need to buy? Sorry, I know I'm being lazy by not using that google thingy..
Deepdiver (04-23-2024)
Promo code 15PARTS
https://parts.gmparts.com/cart
part #
ACDELCO GM ORIGINAL EQUIPMENT FFL-4 ACDELCO AUTOMATIC TRANSMISSION FLUID - 1 QTGM Part # 19418016
ACDelco Part # 10-4130
price is $25, less 15% discount and free shipping
part #
Promo code 15PARTS
part #
part #
This depends on your local dealer pricing. My local dealers charge full price ($44.96).
capacity
Regarding liters vs quarts - step 7 of the track fill procedure in the 2020 Service Manual that I have says "7. Add 2 liters of transmission fluid." This is done through the top fill port, and it is done after a level check is completed using the normal side fill port.
That same manual says the normal fill is 11 liters (11.62 quarts) and the track fill is 13 liters or 13.62 quarts.
Of course, these would be true regardless of whether the bottles were 1 liter or 1 quart. And as a practical matter, folks are reporting their drain and fill experience is never an exact number of bottles because the transmission is never completely drained.
I do not know if the redesigned die 3 case (and pan) use exactly the same fill.
