Mount tire rate
Mount tire rate
So how much is it to change a wheel by taking the tire off of a standard C8 wheel and placing the tire on a 20 spoke GM wheel. I’m told $100 per wheel including force balance.
I just had new tires and sensors put on new rims. The local shop wanted $100 each. I found a great shop in Miami $50 each. My wife just had new tires mounted on her Silverado $25 each at firestone. The Corvette tax is alive and well LOL.
Received 1,876 Likes
2020 C8 of the Year Finalist - Unmodified
I paid $200 for all 4 at a Chevy dealer, which included Road Force balancing. Work was performed by their Corvette Tech.
In my case, I was swapping out tires to all season tires on the same wheels. But same amount of work either way.
Ron_Attleboro_MA (04-14-2024)
Wheels
$400 just sticks in my throat period
As of last summer, most tire shops in the Des Moines area no longer will perform those dismount/mounts on new aftermarket wheels, or new tires on OEM wheels UNLESS they sold you the wheels or the tires. They have stated they've run into too many customers claiming they damaged a wheel in the process. Not sure we have a mobile service in town, that would come to owner's home to perform such a service.
Had stock wheels removed, tires taken off and moved/mounted to new wheels along with sensors and valves, then balanced and put back on car for total $160 at Chevy dealer.
Makitso (04-16-2024)
Discount Tire (04-15-2024)
Received 19,390 Likes
'20-'21-'22-'23-'24
Discount Tire, if one is available, would be a good place to check. $400 to swap/balance four tires does seem high.
Tires
its still paying a Corvette premium because the machine is used for other models as well and they are $30 per wheel. Just my opinion!!! However, I’m
moving on to other sources next time.
Received 4,734 Likes
I’m told the cost of a touch less wheel and tire machine has risen to $39K so the $ amount has gone to $100 per wheel. I feel
The cost of all tire equipment has gone up thanks to you know who. And these machines have been on the market for years and in many tire shops so I think you are jumping to a false concussion.
Wheels/ Tres
I know it’s not much but my source has impeccable credentials and is 100% trustworthy. Sorry it’s all I have. BTW my source also does top quality work not that it’s important to the $$.
Received 8,874 Likes
I just had this done a few months ago at Discount Tire. Price was $192 plus tax ($48/wheel).
The following 2 users liked this post by JABCAT:
Discount Tire (04-15-2024),
Maxie2U (04-15-2024)
Received 2,238 Likes
Independent Tire/Alignment Shop:
Remove Stock wheels & tires from car
Remove tires & TPS from stock wheels
Install tires & TPS on new aftermarket wheels
Road Force Balance all wheels/tires and install on car
Total: $190 plus tax
I was quoted from our new Discount Tires who uses Hunter Tire Equipment quoted me to unmount and remount and balance set of 4 wheels, total price $115.00+Tax.
I got that quote at the end of Feb of this year when I was considering buying a set of 19-Inch Front 20-Inch Rear 5 Split Spoke Satin Graphite Forged Aluminum Wheel with Machined Edge (Q9O) from a local seller.
Supporting Vendor
Thank all of you for the recognition, It is greatly appreciated.
__________________
Low Prices | More Choices | Trusted Experts | Send us a DM
At The Store: www. discounttire.com
Online Orders: www.tirerack.com
Tire Rack Sales: (833) 514.0330
