Fuse Location Information
Seeking the fuse number and location for the cigarette lighter receptical in the front trunk and the cigarette lighter receptical to the bottom left of the glove box.
Moderator
Fuse box diagrams are in your Owner's Manual (and could vary from year to year). Labeling leaves a lot to be desired. Be aware that the outlet by the glove box is not active all the time (it shuts down after 10 minutes along with almost everything else).
In the 2020 Owner's Manual it appears that fuse 39 and 50 in the Instrument Panel Fuse Block::
39 Rear auxiliary power outlet (I'm guessing this is the glove box one)
50 Front auxiliary power outlet (I'm guessing this is the frunk outlet)
Moderator
Thanks for the reply.
39 and 50 would have been my best guess as well, but do not energize the two cigarette lighter receptacle's. You are correct that the Glove Box Fuse Block is not continuously energized. So the front trunk recepticle couldn't be fused from the Glove Box Fuse Block.
The nomenclature in the manual is wrong. Fuse #50 is the accessory outlet by the glove box and is switched by the ignition. #39 is the frunk accessory outlet and is always on. More info here:
https://www.corvetteforum.com/forums...-detector.html
Zymurgy (04-09-2024)
RKCRLR (04-09-2024)
