DCT fluid drain - Preventive measure?
Always good to use brass as it's softer. But not sure how softer than the aluminum case. The risk reward isn't there for me. If installing the drain fill adapter then I'd be good with it as it's normally a one time install. Mess up the drain plug, replace the pan. Mess up the fill plug hole especially when having 2 extra liters, big problem.
Received 1,876 Likes
2020 C8 of the Year Finalist - Unmodified
My choice for the brass fitting with the hose barb was not a long term application. I hand screwed it in, with NO tools and not 100% of the way in just long enough to fill the DCT with fluid. Then it was removed.... by hand. I could have just held the clear plastic hose in there with NO fitting, but risk that it would fall out, or my shoulder give out holding it. It's only intended as a temporary means of holding the fill hose in place. Had I found a plastic one of the proper size that would what I ordered, but found this for a reasonable price, and bought it.
Ron_Attleboro_MA (04-04-2024)
I look forward to a time when the DCT can be rebuilt instead of replacing the whole box for $20,000.
ZF 8HP90 (strong enough for dodge demon, and an absolute UNIT - fantastic transmission) full overhaul kit is $1,055
Love it. Now let's see how well the C8's DCT holds up over the long term. It ain't no standard or slush box. I hope they got it right but really think they didn't. Why would Maserati that uses the same DCT call for 9300 mile DCT filter changes and not 22.5K like GM? Money grab? Doubt it. GM got the trans fluid wrong on the C7 and it took 2 or 3 attempts to get it right. I choose to over maintain mine especially since GM hasn't figured out how to have the spares logistics in place to promptly deal with warranty issues. If my DCT failed and I could get the car back in a week or two I wouldn't be worried. But too many stories of very long wait times.
Heaven forbid, I might be forced to go back to DDing the Ferrari. There are C8s out there with thousands upon thousands of trouble free miles. I mentioned to someone the other day that one of the service advisors at a dealership I had just bought a "park at the airport" car told me he has a customer than has 68K miles on his. And the guy I told this to said he has a friend that has 85K on his. As I said, if something happens I'll deal with it then..... but, either way, I'm not going to
The following 3 users liked this post by Mitchell_B:
Taking another road trip later today (4/4)... when I get back I'll have around 22K on mine. If something SHOULD happen to my car then I'll deal with it.
I replaced my fluid a couple weeks ago. I bought the recommended nipple but it was the wrong size so I just put the tube through the hole and filled from the wheel well with the wheel removed. Did it at the 15deg angle to put the extra in (2020). I could use a flashlight and see the level through the fill hole. I took out 7 1/2 (by memory) and 8.2 got me to level full and 9.8 to at an angle full. I had bought 10qt so that was really good. Got it from Rock auto.
The following 3 users liked this post by EvanD:
I jacked up the rear with two jacks and put two stands under, pulled the drivers side rear wheel, pulled the shear plate, drained. Lowered to level and put in the side plug to full (to see what it would take and the determine if I wanted to add the extra 2qt.). I then decided to add and jacked the car up evenly sideways 12" (trig says that's about 15deg) and added to full through the wheel well.
Other than the shear plate and some previous owner/ service person had rounded the eTorx bolts it was quite easy.
1/2" id 10' from Lowes but used about 4', 3' even would have been okay.
V Vette (04-04-2024)
#33
https://www.corvetteforum.com/forums...read-size.html
Andybump (04-04-2024)
#35
E-Ray, 3LZ, ZER, LIFT
Received 9,647 Likes
You'll find when the last drop is drained it will take 10 Liters (some is left in filter hosing etc.
Did it all from under the car. Need to remove the aluminum pad to: 1) remove the drain plug remove the DCT fluid 2) to access the fill plug. He is putting that hose into the check level/fill hole. Just need to hunt for that fitting.
#36
#37
NOPE! I said: Need to remove the aluminum aero pan to: 1) remove the drain plug remove the DCT fluid 2) to access the fill plug.
Fixed typo pad to pan and added aero!
#38
Lets say shear plate as that's what it's called. Yes, no reason to tilt if not adding more than the regular fill. I don't see what is unsafe about jacking up the side of the car. Your trained mechanic has a stupid way to refill the DCT in my opinion.
Andy, the fill plug can be gotten too (both to remove and to install and retorque in the wheel well. I see no way to get to the drain, especially to get a torque wrench on it afterwards, without dropping the shear plate, which in the end wasn't that hard to do.
#39
In fact , when that was posted, in the same thread I estimated it would take 15 degrees. That was June 2020- here is the post or you can search! Since I have seen the way folks jack the car to do that and it's totally unsafe. I now put a STOP sign on that post!
Do as you wish BUT calling this great Tech stupid makes you totally ignorant in my book! It's the way others in the shop fill transmissions!
#40
