Why This Bolt ?
8mm x 1.25. The length is 25mm of thread, plus a lead in of 3mm. Actually a 28mm bolt.
I think these will work fine. Amazon.com: 25 M8-1.25 X 30mm Metric Hex Head Sems Bolts 11501188 : Industrial & Scientific
I have a Craftsman socket E16 you can see in the top picture. It is not Torx plus, but it fits the bolt head.
These are special "Flow Drill Screws". They are installed by robots and actually tap the metal they are drilling into. Here's a pic:
Here's a great article on them:
https://www.assemblymag.com/articles...rs-shed-weight
Now that the vehicle is assembled, I'm sure a hex head etc. would work, but Torx Plus is the right solution for the many roles of flow drill screws.
Sr.Random input generator
Even with the special adapter, it was slower to remove these since the socket needs to be perfectly aligned, or else it starts stripping. I don't have time for that, sorry! Just source Hex M8-1.25 x 25mm, and you're good : )
Mark9 (03-29-2024)
My 2020 has low profile Torx Plus external wrenching bolts to secure the shear plate. I purchased a Lisle Torx Plus socket set just for these bolts:
While the Lisle set isn't advertised as low profile sockets they have a very shallow chamfer compared to other Torx Plus sets. Real low profile Torx Plus sockets are expensive. The other option is to grind down the chamfer until the socket can get a good bite on the head. Using regular Torx Plus sockets on low profile Torx Plus bolts can strip the heads.
cmonkey713 (03-30-2024)
https://www.amazon.com/Lisle-83100-E...IaAouiEALw_wcB
RKCRLR (03-29-2024)
I made a thread when I changed my DCT fluid and attached the applicable sections from the service manual for removing/installing the shear plate which includes the torques:
https://www.corvetteforum.com/forums...dct-fluid.html
The following 2 users liked this post by RKCRLR:
cmonkey713 (03-30-2024),
Ron_Attleboro_MA (03-30-2024)
Just astounding the technology that went into the design and application processes for these screws.
Unless significant tension strength is required, I often replace steel screws/bolts with stainless steel just to avoid the appearance of rust. General purpose stainless steel screws/bolts are not very strong for tension loads. They really need anti-seize and it doesn't take much of a tension load for the heads to pop off.
Received 19,366 Likes
'20-'21-'22-'23-'24
Have not run across any of those type of bolts yet. I guess weight savings, no matter how small, is a good thing.
#33
Yes, Self tappers = danger. You don't have too many choices with those, just put it back in and tighten carefully.
The bolts under the car on my 23 are not self tappers. You can see the lead in in the post #1 picture. No threads for the first 3 mm. No self tap threads.
They do look like that Torx Plus head. Amazing what you can learn about bolt technology.
Oh Brother. I bought external Torx sockets and had to modify all of them in the lathe because they had a deep chamfer that made them useless.
Now I have to buy Torx Plus.
The following 2 users liked this post by cmonkey713:
C5racecar (04-04-2024),
#35
RKCRLR (03-30-2024)
#37
The problem with button head screws in an undercarriage environment is they can get damaged during scraping and become a PITA to remove. At least with normal fasteners you can usually get vice grips on them if all else fails.
22c8z51 (03-30-2024)
#38
Did someone say weight savings? 🙃
How about some titanium hardware!
These look more aerodynamic too.
https://a.co/d/i2ozdps
C5racecar (03-31-2024)
#39
These were perfect for me. Exactly what I wanted. Big washer. Exactly the same length at the original.
Maybe they will rust eventually.
I took the lower panel off today to find something I dropped. Found a few treasures in there. I found parts I had forgot were lost.
