First Trans Service/Oil Life Dilemma
Currently at 6,016 miles. Original oil life is down to 19%. Earliest I can get the required 7,500 mile transmission service and have it covered by GM is around 7,200-7,250 according to my dealer. I was planning on getting both done on GM's dime at the same time, but now with only 19% remaining oil life I may have to bite the bullet and pay for the 1st oil change out of pocket and save the transmission service which GM will pay for for when 7,500 rolls around. What to do?
They only pay for one oil change. It is up to you to decide which one you want to apply it to. Currently you have two years to get it done. I would pay for the engine oil change and take the 7,250 appointment for the transmission filter change on their dime.
The following 4 users liked this post by Rocketmanwpb:
I don't quite understand your dilemma but an oil change is cheaper than DCT filter change...If you can't make it to 7k miles for your free service then pay for your oil change yourself when you hit 0% and and have the first free service before 2 years. If you have a 2023 or earlier you could have your DCT filter changed before 7K miles and try to play ignorance since GM hasn't notified owners that if the DCT filter is changed before 7k miles it must be changed again between 7-8k miles.
The following 2 users liked this post by RKCRLR:
Fishfryer527 (03-26-2024),
Ron_Attleboro_MA (03-23-2024)
You'll be fine. Get the appointment scheduled and bring it in as you mentioned.
19% = 10 weeks
19% = 10 weeks
The following 2 users liked this post by Kracka:
JerryU (03-27-2024),
Scruff Vette (03-23-2024)
The following 3 users liked this post by Mark9:
I agree. The time limit is very conservative to cover all ends of the envelope. Don't worry about hitting 0%, you will be fine. Just don't drive a long time after you hit 0%.
St. Jude Donor '15
If you have good enough weather in your area over the next month, maybe take a road trip on a weekend to quickly put another 500 miles on it and have some fun while doing it. Being in a somewhat similar spot, that's my plan...soon.
Received 1,552 Likes
2022 C8 of the Year Finalist - Modified
The following 2 users liked this post by MarkMeHopeful:
kromdom (03-23-2024),
JT
Moderator
Received 3,589 Likes
I read somewhere that you are fine +- 1000 miles on the 7500 mile service.
From the 2023 owners manual
The initial transmission external canister
filter change must be performed at
12 000 km (7,500 mi).
Caution
The transmission external canister filter
must be changed at 12 000 km
(7,500 mile) during the break-in period.
Failure to replace the external canister
filter can cause damage to the
transmission and potentially void any
warranty.
warranty.
JerryU (03-27-2024)
Gotta like their wording.
And from the same document
JT
Engineering recommends that the filter be changed as close to 7,500 miles (12,000 km) as possible – plus/minus 1,000 miles (1,600 km) should not be detrimental.
Check the transmission fluid life percentage. If the percentage is less than 10%, replace the fluid and filter. The initial transmission canister fluid change must be performed at 7,500 miles (12,000 km), and every 22,500 miles (36,000 km) thereafter.
If the canister filter is replaced more than 500 miles (800 km) prior to the initial 7,500-mile (12,000 km) break-in period, the filter still needs to be replaced again within plus/minus 500 miles (800 km) of the 7,500-mile (12,000 km) service interval.
JT
Scruff Vette (03-26-2024)
E-Ray, 3LZ, ZER, LIFT
Received 9,640 Likes
You ONLY need 7500 miles +/- 500 miles to meet the requirement to have the DCT filter changed. So OP's dealers saying min 7200 miles is NOT right. At 6200 miles you only need to drive ~800 miles in two months. SMART to just make a long drive in the next several months IF needed. Can do, if when the OLM says 5% life left, the OP is not there!
Show the dealer this GM doc:
Since they don't appear to know it can be done at 7000 miles be sure they do know a FLUSH as it is required (and IMO important to get early part, clutch wear flushed.) Heck I and many had it done year 1 on GM's dime, in my case with ~3000 miles. Dealer gets reimbursed for one REGARDLESS of miles. You just have to have it done again at 7500 +/- 500 again. I had mine done at ~8000 miles year 3 when ALL DCT fluid had to be changed. All on my dime. In fact for my new E-Ray where I will have 2500 to 3000 miles year one I'll get my free engine oil and DCT filer (with flush) done. Probably be my dime year 3 as this is my 7th Vette, I don't use for log trips but is my DD!
Scruff Vette (03-27-2024)
THE OFFICAL GM STATEMENT IS WHAT I POSTED 7500 +/- 500. Also if DCT filter is replaced at say 6500 miles do it again at 7000 to 8000. That has been validated by GM Exes when asked. You may not think that is smart but GM's Warranty their rules! Some may think a joke BUT if the DCT fails in the 5-year warranty and you didn't follow what has been clearly communicated for 4 years could be your $20,000 bill for the replacement.
JT
JT
Will GM deny a warranty claim if its is with 1000 miles? Who knows. I have heard in a video a GM rep who claimed to be one that actually assessed claims, and he described a process of looking for reasonable compliance generally (not specific to the DCT filter). They may or may not be picky about the DCT filter change window - but suppose it was changed at 6000, and then at 9000. It would seem unlikely that a transmission issue, should it arise at 10000 miles would have been caused by a DCT filter issue. I'm still sticking with the +/- 500 though.
