2020-2024 C8 Corvette Z51 Carbon Fiber Rear Diffuser Fins - Available at RPI
Platinum Supporting Vendor
Available here : https://www.rpidesigns.com/shop/item...diffuser-fins/
Code : Anuran7
Enhance the aerodynamic performance of your 2020-Present Corvette Z51 or Stingray with our C8 Corvette Z51 Add-On Rear Lower Diffuser Fin. This dynamic accessory, not compatible with C8 Corvette Z06 models, is meticulously crafted to maximize the aerodynamic attributes of your vehicle, providing optimal downforce and stability at high speeds.
Constructed from durable ABS plastic, the diffuser fin boasts a Carbon Flash Metallic/Matte Black surface finish, ensuring both functionality and a sleek aesthetic. The lightweight nature of the ABS plastic not only contributes to improved vehicle performance but also aids in reducing overall weight.
The single vertical fin design attaches seamlessly to the lower edge of the rear diffuser, extending downward towards the road surface. This strategic placement creates a low-pressure zone underneath the vehicle, effectively pulling the car down and diminishing aerodynamic lift. The result is an optimized driving experience, especially at higher speeds.
For a hassle-free installation process, we provide a comprehensive package that includes the C8 Corvette Z51 Add-On Rear Lower Diffuser Fin and a bag of hardware. Prior to installation, it's crucial to ensure the vehicle is clean and dry. Verify the availability of all necessary tools and hardware, then locate the mounting points on the part to be attached. Perform a test fit to guarantee proper alignment and fitment. Finally, use the provided hardware to securely attach the item, and you're ready to enjoy the enhanced aerodynamics of your C8.
Invest in this premium aerodynamic solution to elevate the performance and aesthetics of your Corvette. Drive with confidence, knowing that your vehicle's stability and downforce are optimized for an unparalleled driving experience. Get yours today from RPI Designs!
Fitment: 2020, 2021, 2022, 2023 C8 Corvette
Code : Anuran7
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
