Z51 with mag ride control, what's up?
The Chevy.com website configuration tool won't let me spec Z51 with mag ride control. When I select MRC it says you have to delete Z51.
I called a dealer and they walked through the order process and it let them check the boxes.
Popular Reply
02-22-2024, 09:02 PM
Received 6,934 Likes
You do know there are 2 different mag ride options to choose from on the "build and price" website you should be using to configure your build...One is for non-Z51s and the other for when you have the Z51 option already selected
I'm going to guess you selected the non-Z51 Mag Ride option which would tell you to delete the Z51 option that you had already selected...
Maybe the the tech guys need to work out the kinks in the website configuration since the dealer was able to configure it on their end.
Landru (02-23-2024)
you do know there are 2 different mag ride options to choose from on the "build and price" website you should be using to configure your build...one is for non-z51s and the other for when you have the z51 option already selected
i'm going to guess you selected the non-z51 mag ride option which would tell you to delete the z51 option that you had already selected...
