Z51 better acceleration handling?
#61
Straight from the manual:
“To experience the performance benefit of this system, after entering a curve and at the point where normal acceleration occurs, fully press the accelerator pedal. The PTM system modifies the level of engine power
for a smooth and consistent corner exit.
#62
Oops, wrong poster. Thanks RKCRLR
#63
I really can’t believe these non-z51 arguments don’t get laughed at for being completely ridiculous at face value. The z51 has stiffer springs and larger sway bars, there is absolutely no way that it is not noticeable during normal driving. Sure the improvements may not make a meaningful difference in speed on the street and a z51 probably won’t walk away from a non-z but that doesn’t mean it won’t be a more competent feeling car
The following 4 users liked this post by AMXJim:
#65
E-Ray, 3LZ, ZER, LIFT
Received 9,647 Likes
As I mentioned, Tadge had a long, several page post re eLSD operation in Ask Tadge. The Chevy Performance Engineer in charge of eLSD Integration wrote most it. It was for the C7 but probably similar in the C8.
I summarized the key points as it's a bit hard to follow (and long.) In the Appendix I included the full Ask Tadge/eLSD engineer's post:
eLSD_VS_Posi.pdf (netwelding.com)
Have several Video Links in the Appendix as well. One from a Professor who discusses the late 1950's invented Positraction (by Dana) most manufacturers used under their different marketing names. He takes 11 apart to show how they work.
The eSLD engineer provides some interesting data. The C6 only had that 1960's Positraction. It only operates when one wheel is slipping and the most torque it can supply to a rear wheel is 88 ft-lbs. eLSD can apply up to 1475 ft-lbs of torque to either wheel. All controlled by a computer integrating the many sensor data. It's operating all the time including assisting in turns.
#66
This Everyday Driver shootout comparo among a C8, 911, Artura, Elise, and GR86 has results that will be unpopular in this forum. I won't say where the C8 ranks but it's lower than the budget GR86. This video sort of validates my initial concern about driver engagement. Z51 doesn't fully fix that but at least tends towards mitigating it which makes it a bare minimum requirement for me. All in a street context.
#67
Z51 is better for me
I had a 2010 1lt convertible without Z51 or mag ride. It was beyond a doubt.not a great handling car. My ‘99 convertible with msg ride was so much better in terms of regular commuting and weekend curve carving. My purchase of a ‘23 3lt with z and mag ride is a totally different story. It handles like a true drivers car. Of course you can save a bunch of money by getting a 1lt. By virtue of the fact it’s a mid engine car it will handle better than you 2010. But not as well as my 23. You have to ask yourself if you want the most technically advanced corvette or just a regular one. If you’re looking for a Ferrari 580 or similar car then get both the mag ride and z51. If you don’t care about those types of ride and handling vehicles and just want a vette then get it without. After taking the Ron Fellows course I was thanking myself for getting both. It provides a spectacular experience.
TNBatmobile (02-04-2024)
#68
Sorry but I am going to start the controversy..
I say the Non-Z51 is equal on the streets as the Z51! I admit the Z51 is better on the track but mostly due to brakes and cooling.
Get a friend with Z51 and see he they can loss you again on public roads, even canyon roads.
JerryU (02-05-2024)
#69
Received 2,530 Likes
Here we go again........
#71
Forgetting all our personal opinions, or what a friend who's a race car driver said, etc, will repeat what the MAN, father of MRC and GM person who helped develop handling packages said as I did in post #17:
The following 3 users liked this post by JerryU:
#72
That question has multiple answers, the first is it depends on the driver's skill, what tires are on the car, the temperature. I spent years teaching drivers and it is not usually the car that is the weak link it is the person behind the wheel. I drive without traction controls and the C8's limits (my car has the Z51 package) are hard to reach on the street unless you are breaking the law or trying to.
That said, you are always going to feel the stiffer suspension, or softer ride feel as well in Tour if you have the MSRC option. The stock 1LT with no MSRC and no Z51 shouldn't be able to match the softer ride characteristics of the Z51 with MSRC.
If you hate brake dust, don't get the Z51 though. The two biggest complaints are usually brake dust and the fact the rotors get rusty nearly instantly.
The dust is easy to handle because it's a good idea to switch back/forth from street pads to track pads as needed. The rotors are a bit more costly and difficult to deal with though.
#73
FWIW, the PDF I wrote re eSLD showed what you'll see on the center screen if you elect to put it up. The eLSD is applying the rear wheel clutches all the time to "some degree" to one wheel or the other except going straight. Even there depending on road surface. Not sure if a light comes on if it applies the full 1400 ft-lbs if you're about to slide off a turn? netwelding.com/eLSD_VS_Posi.pdf
Perhaps it's no longer available for display? Tadge did say in his Ask Tadge Post as I quote in full the PDF:
"Also, I would be remiss if I didn't remind everyone that the eLSD does some of its most important work in some pretty aggressive maneuvers. That is not the time to be looking at the display.... First priority is to keep eyes on the road!"
SIDEBAR:
That Tadge statement reminded me of a friend in college who raced his Lotus 7. We'd discuss his SCCA training between classes. Recall drawing a parabola on a blackboard and discussing why it was the fastest path thru a tun etc. We both drove the same twisty single road through a Park, often no traffic or people. Neither had fast road cars but drove as fast as they would go. He asked "How fast you make the one very shape turn." I said never looked. He said good, if you're going as fast as you're capable you're looking ahead not at a speedometer! Back in ~1962, no PDRs!
SIDEBAR:
#74
JerryU (02-05-2024)
#75
This is a never ending debate that will get you different answers based on what people own. Everyone has opinions, so here's mine. I own a 23' Stingray with the FE1 suspension. I had ordered a car with FE2, but didn't get it for reasons you don't care about, ended up getting a car with FE1. I was concerned about it being too soft. Weekend toy only, spirited canyon driving. It has been great. However, because I like messing with my cars, I purchased a Z51 rear sway bar (the front sway bars are identical on Z51 vs non-Z51) and also Z51 springs. I'm gonna put the sway bar on and see if I notice anything, then maybe the springs. Do I need to, no I don't, the car is fantastic as is, but that's me. I swapped with a buddy and drove his C8 Z06, again just street. Felt stiffer obviously, but for the street not wanting to go to jail I wasn't able to take advantage of the Z06 performance so not really a noticeable difference, other than exhaust note. I'm not really answering your question, just rambling, but here's what I think is a logical summary. Z51 cars handle better, period, I don't know how you can argue against that. Do I think it will make a noticeable difference on the street? Maybe a little, but like folks have mentioned unless you are really skilled and are driving crazy fast on the street you're gonna love any C8 suspension because I truly believe they are all really, really good. Mag ride is pretty cheap so if I were to order again I'd get it for the adjustability, but I'm certainly happy with my FE1 suspension, it's so much better than I expected. Best of luck......
As soon as I read your response, I knew we had something in common, our career field and confirmed it by your call sign. I'll be upgrading soon to the 24 Z06 mainly for the exhaust notes and performance. I do track my vette for fun and have attended Ron Fellows a couple of times...can't wait for the next experience.
Live Long and Prosper!
langhorne_bill (02-05-2024)
#76
If you are going to track your car, get the Z51....period. As for acceleration, maybe not so fast. The C8 launch control is traction limited.... the Z51 puts down more rubber??
My Stingray has 21x12 rear wheels with 325/25/21 Michelin rubber (Z06 is 345/25/20!). I doubt I have any difference 0-60 with a Z51. My car hooks way better than the stock 305/30/20's did for sure. I get a routine 2.8 on the timer--on crappy CA fuel (I know this is not an accurate reading). If you are keeping stock wheels/tires.... go Z51 if tenths of a second in acceleration are important to you.
