Dealer can't do HTC oil change in cold weather
Took my HTC in for its scheduled annual oil change today. Of course, the weather in DFW is on the cold side for a few days. Dealer just called and said they can't get the HTC top to operate in the cold temperature. Going to leave it under the shop heater and see if they can get it to operate this afternoon or tomorrow. Oh well, fun and games.
Jeeez how cold is their shop?
You would think pull it the bay let it warm a bit and open?
Received 1,409 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
I guess they'll need to figure it out. If they can't access the engine then they have a warranty claim to deal with. Once they have that solved they can then change your oil.
The owners manual says this:
I'm going to assume it's not below freezing inside their shop, so all the probably need to do is let the car sit inside for an hour or two until it (the car) warms up some. There are lots of Corvettes in cold weather climates, and it's ludicrous to think none of them can get an oil change in the winter.
At cooler outside temperatures, the
convertible top may not operate. It is
possible to open the top down to
temperatures of about 0 °C (32 °F) and
close the top down to temperatures of
about −10 °C (14 °F). A DIC message will
display if the top will not operate due to
low temperature. If necessary, move the
vehicle to a heated indoor area to operate
the top.
the top.
The following 2 users liked this post by Red Mist Rulz:
billclerm (01-20-2024),
Ron_Attleboro_MA (01-17-2024)
PaulCPO (01-16-2024)
One would think the engine generates enough heat to get the mechanism to 32F. I know my trunk is toasty after an hour drive.
The following 2 users liked this post by gdb069:
JerryU (01-17-2024),
Received 5,235 Likes
All the "fixes" would take time, time the shop doesn't want to deal with.
Glennm27 (01-17-2024)
Received 19,368 Likes
'20-'21-'22-'23-'24
Hopefully they were able to get the car to warm up, get the top to operate and then get your oil changed.
I was in a parade last year and the temp was well below 32. My HTC would not operate. I got a warning it was too cold. Tried multiple times. Another person with our group had no problem raising and lowering his. Don’t think it had anything to do with the temperature around the engine or frunk. I suspect it takes the reading from the same sensor that tells you what the ambient temperature is outside wherever that is located. Sam.
tsigwing (01-17-2024)
Programming. Protecting you from freezing yourself. I would hazard a guess that it could cause issues with raising it back in place if it is too cold.
I would expect it could also be an issue if any loose ice got in to the mechanism. It doesn’t look that robust to me.
If water is frozen (ice, sleet, snow) between the panels or The rear deck & trunk or corner panels. It would effectively glue the hardtop in position. if you operated it, more than likely it'd start popping teeth off the gears or bending linkages. Pretty much destroying the hardtop system.
Steve
Steve
