rear caster tool
You need the GM tool to set rear caster to 0 degrees. Hunter Alignment systems can only measure front caster. My 2022 Z51 was at +.5 to +.6 camber front and rear from the factory. Rear caster was off by +or- 1 degree. Not a problem for a street setting.
I use +1.5 degree camber front and rear, 0 toe front, .10 toe in rear, 0 degree caster rear for a street driven car on performance summer tires with no unusual wear.
BearZ06 (01-11-2024)
You use positive camber?
