Blind spot mirrors
Received 2,240 Likes
If you adjust your mirrors correctly, there is no blind spot. And contrary to the post above, why people haven't learned to do the "full head swivel" is because you're not supposed to take your eyes off what is in front of you.
But people still refuse to adjust their mirrors correctly, add goofy extra mirrors, and look over their shoulder like they were taught in the '50s.
https://www.caranddriver.com/feature...d-blind-spots/
Installed the Paragon mirrors right away. No blind spots. Still can't get used to the rear camera regardless of settings but the majority of time, my top is down so it doesn't matter.
Silverado 2500 'trailer' two section mirrors
On my 2023 Chevy 2500 I can see both door handles in the factory crew cab mirrors on drivers side. I look at the bottom lens for less than a second and move out smartly (Army terms) and change lanes. Just put wall mart 3 inch convex mirrors on lower outside of factory mirrors and it works just as well. It cost about 3 bucks. Am thinking of removing the one on the passenger mirror.
Received 8,878 Likes
If you adjust your mirrors correctly, there is nothing you can see out of a Corvette by turning your head that wouldn't already be in your mirror or peripheral field of vision.
Sweetness34 (04-29-2024)
Not one of your links discusses how to adjust the mirrors to eliminate blind spots, they all assume you have one. I could post list of things taught incorrectly in my field too. Just because it's still being taught, doesn't make it correct.
Facts and reason will never change someone's mind if they formed their decision in the absence of same.
You trust mirrors. All experts say that is a very poor practice. May no one ever pay the price of your failure to head check. At least someone new reading this thread is informed.
Peace!
Moderator
The following 3 users liked this post by Zymurgy:
"If you adjust your mirrors correctly, there is no blind spot."
I have supported the above idea for a long time but the C8 configuration is different than most cars. The problem is that the actual driver's side mirror is significantly further away from the driver than in all other cars I have ever driven. Being further away means that the area that they can cover and can be seen is dramatically lessened and that's what creates the blind spot no matter how they are adjusted. To increase the area that is covered, I have always installed a wide angle convex mirror on the drivers side of my cars. And that is what is desperately needed on the C8. The easiest method of doing that is with the stick on convex mirror sold at this website: Panoramic Door Mirrors | Sandyeggo Designs
The difference between that mirror and the standard "flat" mirror as far as the area covered is significant and then properly adjusted does eliminate the drivers side blind spot completely
"Mirrors Only Say No" is so elemental, there is no argument to counter someone who denies it. It's like arguing against "Wash your hands before you eat". "I keep my hands clean, that's an old wives tale, I don't wash my hands before I eat if I've kept my hands clean".
Peace!
Peace!
So as you said "facts and reason..."
Mine cannot.
"Correctly adjusting eliminates blinds spots" does NOT eliminate your responsibility to visual check where you are going WITH YOUR EYES. Try driving with a blacked out windshield and a set of mirrors that allow you to see where you are going with no blindspots. It's obvious to you that it would be possible to set that up, but nonsensical.
"Did you LOOK before you lane changed???" "Well... I checked my mirrors but no I did not look... sry"
Peace!
Peace!
The following 2 users liked this post by StfDrmsRMadeOf:
Walt White Coupe (01-07-2024),
Waterline (01-07-2024)
#33
Mirrors Only Say No. Consistent in all professionally delivered training. Some "ANSI engineers say you may be able to adjust mirrors to eliminate blind spots" doesn't cut it.
Changing lanes? Look first. Not difficult. Not complicated. 1/10th of a second off your life that may save another.
Not mandatory of course, and it's likely that disregarding this basic procedure may never cause harm to you or others. And apparently a lot of folks get some sort of "cool vibe" from never looking before moving into another lane.
I am surprised at the size and energy of the group that says "Forget best practices. I'm too cool, I have on my mirror shades, I look at the mirrors which I have professionally adjusted, and I get a charge out of moving into another lane without even a single glance at where I'm going. Because I'm that good at adjusting my mirrors. I know mirrors NEVER get bumped, never get out of adjustment, they are infallible. My head never moves. Chicks swoon."
Whatever kicks ya.
#35
sshallen, Thanks for reminding us that the images we see in mirrors are not real. How could anyone believe that what they see in a mirror is real? I think we are seeing something from the great beyond when we look into mirrors. Don't trust them.
#36
I think the rear view camera, mirror warning indicator, and no convex on the mirror makes for some junky technology. You might be safe in relaxed traffic differentiating with the mirrors and camera joyriding the c8. Driving it in serious california traffic it’s just too clunky. Saying to turn your head makes no sense as all you see is the nacelles on the convert and with the top down you don’t even have the camera… There are several high end cars with simply wonderful blind spot tech-and those cars have good visibility already.
Being a cool, mid engine car is no excuse for having cheap tech- that is what the real debate is about here….
#37
Moderator
S5.2 Outside rearview mirror—driver's side.
S5.2.1 Field of view. Each passenger car shall have an outside mirror of unit magnification.
#38
Have used small rectangular convex mirrors on all cars owned. They have served flawlessly. When I purchased C8 coupe, 1LT, drove from the dealer in Delaware to Philadelphia, without these. Was concerned about the right side blind spot. Arrived home, purchased and installed the mirrors. Now the entire vehicle coming along on the right blind is seen in the mirror. Therefore, as with past vehicles, these mirrors have solved all my blind spot problems. $5.00 each. They're small, Approx 1.5" W x 1.0" H, and pose no significant obstruction to the regular mirrors. Have no effect on aesthetics. In fact, I like the look.
At night, depending on road lighting and other factors, if a black vehicle comes alongside with lights off, they might not serve their purpose, but in that type situation, probably nothing is 100% fail-safe.
#39
When mirrors are adjuster properly there are no blind spots on cars. I finally learned the right method about 25 yrs ago, and eliminated blind spots since.
1- lean you head against the drivers window and adjust side view mirror to just see the edge of the car.
2- lean your head far right and adjut the passenger side view mirror to just see edge of car.
As you drive you will see a car in either lane beside you move up and about the time it moves out of the rearview it will move into the side view, and as it moves out of the side view it will move into your peripherial vision.
I have found it works on most every car, C8 included. If you have the camera mirror, all the better. You should have no blindspots.
#40
I assume if you install the paragon mirrors you no longer have the warning indicator which is not perfect, but does help.
