Downshifting.
Downshifting.
I'll preface this with, please forgive my ignorance because this is most likely a silly question. I have had my C8 for a little over a month now and I've driven it enough to get fairly comfortable with it. With that being said, this is the first true sport car I've ever owned or driven. So I'm still learning about it obviously. One of the things I've noticed is that at very low speeds the downshifts sometimes feel very abrupt and can, at times feel somewhat jerky. I'm assuming it is normal but wanted to make sure by asking people on here that know more about these cars than I do. My C8 is a Z51 and when it is shifting from 3rd to 2nd and especially 2nd to 1st at speeds anywhere from 20 to 0 mph the rpm's will increase around 50-100 upon downshift. I've never really paid much attention to it until I started watching my truck when downshifting at low speeds. While there's an rpm increase it seems much more, "smooth." Again, is this normal is should my low-speed downshifts be more smooth?
Ron_Attleboro_MA (12-21-2023)
You didn't say whether you were driving in automatic or paddle shifting. The transmission will smooth out over time but if you are manually downshifting, you will feel a slight rev match to make the shifts a little smoother and to some extent you will feel that in automatic mode as well. If the downshift occurs towards the top of the rev range, the shift will be more abrupt. The slower the car the more abrupt feeling it will be. Frankly, I just leave it in auto and let it do the work for me. It's a very intelligent system and can react appropriately much faster than I can. Even Randy Pobst said that when he first drove the car on a race track at VIR.
Fast Dawg (12-21-2023)
I haven’t noticed this, but I’m usually in manual mode.
When I first got mine I felt the same thing. It’s better now, it’s been 7000 miles for me. I’d say it stopped being like that maybe 2-3000 miles in.
Mine was in my mode, which I believe is always tour
One thing to remember, this is a manual transmission, not an automatic. There is no torque convertor to smooth out the shifts.
If this was a stick shift car, would you be any smoother when downshifting every gear. Probably not.
I do notice some downshifts not being perfectly smooth, but I am always amazed that it is downshifting without any input from me.
With all of the electronics in the transmission, they probably could make the downshifts smoother, but then it would not feel like a real sports car.
It would feel like a slush box luxury car.
I do notice it downshifts harder in Track mode or Sports.
Just turned over 18,000 miles on a 2023 and it is much smoother than when it was new. Just leave it in auto, learn to drive, see out of the car and enjoy it as is. Do your manual shifting later. My 2 cents.
C5racecar (12-22-2023)
You will definitely hear the downshift as the engine rev matches the gear. Possibly that is what is making it seem jerky. If you are actually having your head nod forward, in Tour mode with standard settings, you have an issue.
Received 2,899 Likes
It could be the transmission fluid temperature. When cold the shifts aren’t as smooth as when the fluid is at operating temp.
That is why I have never done spirited driving till all temps have reached normal operating temp in any of my Corvettes. More wear n tear is done at cold temperatures than at normal temperatures.
My 24 HTC feels the exact same way. 3rd to 2nd is most pronounced for me. 2nd to 1st is fine. This normally happens in D. When in manual, the low speed 3rd to 2nd shift is much smoother. Wondering if it has to do with the way the DCT has learned my driving habits. Absolutely babied her the first 500 miles, driving in Tour 90 percent of the time. After break in, I've regularly been in Track mode, driving in a spirited manner.
In any case, going to monitor and have a tech check it out when I go in for regular maintenance.
