is the dct transmission issue fixed for my2024?
#41
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
^^^ Yes, I think we've seen some with 10K miles or more that had issues, but not much more. Then again, there aren't a whole lot of cars yet on the road with 30K + of C8s. Only read of a few, may be more tho.
#42
Received 11,607 Likes
The following 3 users liked this post by Phil1098:
#43
To be clear, the problem is unacceptable and should not exist after 5+ years of production regardless of the price.
#44
What is the problem with the transmission? I had heard early on that it was failure to remove material left behind in the manufacturing and it was plugging ports. What is failing?
#45
Am I supposed to apologize for stating what the Corvette tech that I've known for 40 years told me? I asked him specifically how many he has had to change out on C8s and he said zero. Almost every time I walk in the shop he's changing a transmission in something, just not a C8. I know of three of the GM 9 speeds in the new Blazer that have **** the bed. I have two friends that own the new Blazer, one has transmission issues, and the other one had a catastrophic failure.
#46
Honestly, I think it's more that GM is trying to get their arms around issues they've had. ANY new major component has the SOP of dealer not allowed to open, crate and replace is all the dealers are allowed to do. As time goes on there will be dealer training and like any other transmission they'll be allowed to open it to see what's wrong. I have yet to hear of a serious failure, I.E. stripped splines, bent shift forks, exploded clutches, etc., it's still control related with sensors and solenoids. That doesn't taste any better to the customers that "need" a new DCT, but it's how it is right now.
The following 5 users liked this post by Phil1098:
DerbyCity (11-26-2023),
Didier9 (11-27-2023),
kromdom (11-26-2023),
LE MANSZ (11-26-2023),
Zaro Tundov (11-28-2023)
#47
At my dealer of preference, they have some of the best techs in California. They have a tremendous reputation as corvette specialists and the GM of the dealership is an avid corvette enthusiast and races them from time to time. I was told by the GM and the tech that the sensors and solenoids in the valve bodies have very small passage ways, easily prone to plugging by the smallest of particulates. I don't know if this debris is from the manufacturing process or from the clutches wearing in and shedding debris. Regardless, in my opinion, this is the cause of the majority of issues with the DCT. But this is just my opinion, and I could be wrong. My dealership has also said that they haven't had a large failure rate on the DCT, and I believe have only actually replaced one or two of them. My hope is that GM/Tremec is learning from this and will update the valve bodies in the future to be less prone to plugging.
#48
Received 1,991 Likes
Dave O. Sounds like you got a great dealer! Why not name them please? Folks might appreciate a great tip!
DerbyCity (11-27-2023)
#49
David, thank you for your reply. Do you know if I will have a repaired DCT put into my Vette?
Undy (11-28-2023)
#52
No way it is that small. That would be only 3 cars per year with a transmission issue. My dealer had several Corvettes backed up before me with DCT issues.
The following 2 users liked this post by bmanahan:
Crossofiron (11-27-2023),
tadda (11-27-2023)
#53
Just providing some data on my Z06 DCT failure in case you haven't seen my other posts.
Leaking oil from the DCT from day one. Noticed the puddle on the floor in the garage after 69 miles.
Removing the aluminum shear plate revealed oil coming from the driver-side half-shaft DCT seal.
Dealer shop foreman said he could move the half-shaft up and down allowing oil to run out.
Looks like a bad bearing to me but maybe more complicated than that.
I did see some smoke coming from the engine in the rearview mirror when stopped in traffic.
Waiting for over 2 weeks for new DCT but no ETA from GM.
It sucks being the 1 in 100 or 10,000 that fails.
#54
I believe they switched to the new design sometime in late June or July, shortly before the '24 MY. Mine was built late April (delivered in May) and I believe it has the original design.
I do not believe the "new design" has much to do with the hard failures people reported. I have read that the new design fixes the issue with track use and the need to add 2 quarts for the track (long turns at high speed which forces the oil to the side of the case and out of reach of the pump.) The new design adds baffles in the transmission pan to reduce that effect. It may address other issues but I have not seen anything other than the baffling. In normal street use, you should never encounter that effect. If you do, you should maybe reconsider your driving style on open roads
#55
100? That’s tenth of one percent of the C8s out there. Hardly convincing.
#56
#57
I had concerns about this and thought that it was corrected by now ( April 2023 ) Never would have thought that I would be one in 10,000 (;
This Wednesday it will be three weeks without an estimated replacement.
The following 2 users liked this post by DerbyCity:
kromdom (11-28-2023),
RiptideHTC (11-27-2023)
#59
Mine failed at 80 miles.
#60
