Does NCM Correct Issues?
Saw this while visiting the NCM today. Would they send this back to the factory get fixed?
Curious because I was debating on having my delivery there.
The following 2 users liked this post by 5632:
Red C8 of Jax (10-21-2023),
Ron_Attleboro_MA (10-21-2023)
They don't do anything different than any dealer. In all honestly, probably less so in that you are not really their 'customer' per se. The crooked stitching thing has been beaten to death. The C8 is a car that gives you the 'experience' of cars costing twice as much. There are going to be compromises. Porsche has a $150K 911 Carrera S for you if this is unacceptable.
Received 19,347 Likes
'20-'21-'22-'23-'24
No, the NCM will not correct that issue. If you do take delivery at the museum and you car ends up having that problem, speak with your local dealer when you get home.
The following 3 users liked this post by Vetteman Jack:
I did the museum delivery on my 2016 Z06, they had the car for 4 weeks before I picked it up.
As soon as the museum representative opened the drivers door I could see wrinkles in the drivers seat, I said why didn’t you get this seat replaced since you had the car for 4 weeks.
The representative’s response was we see a lot a Corvettes with those wrinkles, of course my response was really look at the passengers seat it’s perfect and that’s how the drivers seat should be.
This put a damper on the rest of the day, all I could think about is now I have to bring this to a dealer and get it replaced.
The following 2 users liked this post by gve:
Indy Jim (10-21-2023),
loclowd (10-21-2023)
I said they won't do anything different than any other dealer. Any dealer will repair/replace/correct a mechanical issue like your broken lumbar adjustment. Same goes for a bricked infotainment screen/non-functioning drive select mode/broken exhaust valve/faulty TPMS/etc. No dealer is going to proactively replace components because stitching is mis-aligned or there are some slight wrinkles in the leather. Nor will the museum.
[QUOTE=combatninja;1607160473]They don't do anything different than any dealer. In all honestly, probably less so in that you are not really their 'customer' per se. The crooked stitching thing has been beaten to death. The C8 is a car that gives you the 'experience' of cars costing twice as much. There are going to be compromises. Porsche has a $150K 911 Carrera S for you if this is unacceptable.[/QUOTE
To each their own!
I'm back and forth between Museum delivery and intercity (both are same price).
Edit: Thank you so much for all of the replies.. I think I will do intercity to my home. I trust MacMulkin and their PDI process. You guys are awesome, thank you!
Rharfo (10-23-2023)
