My 2023 Corvette Just Started By Itself in Garage. Please Help!
#61
This thread is a good lesson to make sure that OnStar, or similar service, is either cancelled or transferred to a new owner of any used car.
Moreover, those trading in their cars should erase Homelink settings for garage doors, and erase all personal destination info from nav systems.
There can also be a positive side to buying a used car. Years ago, we purchased low-mileage Mini Cooper S convertible, and someone forgot to cancel their Sirius/XM subscription. It was free to us for almost a year.
#62
Is that C8 named Christine?
#63
Received 5,240 Likes
Just another of the surprise "options" you get with a rolling 'puter... occasional glitches. Some might suggest it's just the result of a random quantum wave-function collapse in the electronics... somewhere.
#64
This is the most ignorant statement I've ever seen posted on this forum. Modern emission systems do not clean carbon monoxide from ICE exhaust.
mefly2 (10-17-2023)
#65
All I can say is monitor the car. Unfortunately, without a code or the ability to replicate the problem, a dealership won't be able to do anything.
Hopefully, you have no hacker types who have spied your C8, but you might consider a "Faraday cage" box for storing your fobs. There are plenty of choices at Amazon.
If your fob is on a countertop in range of a scanner in the street, that might have picked up the fob signal. Move it as far away from the street as you can.
#66
I could swear I heard a Car Talk podcast where a caller had this problem (yes, I'm still addicted to the show). IIRC it was a bad solenoid. Of course that was on a car probably decades old and it's hard to believe modern electronics would allow that to happen.
#68
When I was a lad my first car was a 65 GTO and one day I pulled into a parking spot and turned the car off and pulled the key out and it started cranking over with no key....turned out the ignition switch shorted out...lucky it was a manual and I clutched it and stick the key back in and got it to stop before anything else was hurt...Ahh the good ole days...I still miss that car...
mefly2 (10-17-2023)
#69
Received 1,374 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
This whole thread is Much Ado About Nothing, IMO. It's a forum thing but how surprising how so many can overreact.
hawkgfr (10-18-2023)
#70
We had a Dodge Ramcharger at work that would do this, you could slam the door and the truck would crank over. It wouldn't start because the rest of the ignition circuit was not on because the key wasn't on. Ended up replacing the starter solenoid.
#71
#72
St. Jude Donor '19
I would bet it's ghosts!! I have a similar problem with a ceiling fan. It turns the light on every morning (and other random times also) after my wife goes into the bathroom to get ready for work. It's everyday, but not on weekends or when I'm out of town. 3 days in a row it went on at exactly 6:11am, the other days it varies from 6:11am to 6:26am. Very strange! We think it's ghosts, but in all reality it is probably some random signal getting sent to the fans remote control to turn it on. It's just odd that it mostly happens around the same time in the morning when I'm at home and the wife in the bathroom.
#74
OP contacted OnStar after the incident and got that straightened out.
Dads2kconvertible (10-17-2023)
