Why are there no 180 degree headers for the c8?
Popular Reply
10-12-2023, 07:50 AM
Received 19,406 Likes
'20-'21-'22-'23-'24
The engineers did what they could to make everything fit into a tight package area. I think they did a very good job.
Received 5,238 Likes
You ever try to route/wind them all over most tight engine compartments to make them work correctly?
'20-'21-'22-'23-'24
The following 8 users liked this post by Vetteman Jack:
HRDTOPC54FUN (10-12-2023),
joecbrzx (10-13-2023),
khartford (02-06-2024),
mefly2 (02-07-2024),
proeagles (10-12-2023),
and 3 others liked this post.
Tron Z (11-21-2023)
Could probably do that if you were willing to give up the trunk.
hawkgfr (02-06-2024)
Like CholisBill said, the firing order is different than what was used in the old small and big blocks (18436572). One of the reasons GM changed the LS/LT firing order was to get better exhaust extraction without needing 180 degree headers.
JerriVette (10-15-2023)
There are some available for C6 aftermarket.
Of course they would be aftermarket for the C8, the OP wasn’t necessarily asking why GM didn’t make them stock (I don’t think?), but I for one, would pay the extra $ for these on a C8. I’m surprised also that no one has made these yet either. At least that I’ve seen?
Received 1,660 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21
https://youtu.be/yKvi0-UiZ6Y?si=lJQGfQ0o0hbKamLu
Packaging and airflow. The engine sits next to larger rear shock towers occupying more space than a smaller front suspension and/or leaf springs in a front engine car. There's also a giant honking DCT below and a trunk directly aft. Paths also need to be cleared for the side air vents and their auxiliary cooling mechanisms. You could theoretically snake in 180-degree headers but it'd likely have such abrupt bends that choke airflow and rob power vs the current setup.
LS, LT, etc engines have a different firing order than the old small and big blocks. 180 degree headers were a benefit only on the old firing order. One of the reasons that the firing order was changed was so that 180 degree headers were not needed to extract the last bit of power out of the newer engines.
There's an outfit called Celeritech that will build you some of titanium....
The guy in this thread built a set for his C5 you can get a idea what it would take to fit a set to a C8 same firing order
or look at that mess in the post above 🤣
https://www.corvetteforum.com/forums...ld-thread.html
