Best Driving Mode for Autocross
I like to drive Autocross from time to time and I expect to do a few Autocross events in my C8 once it's past the break-in period. In the past I had a Miata for my track car, which has no driver's aides, just wandering if anyone has taken their C8 to an Autocross event and what was the best driving mode? DCT in Auto or Manual? Track or sport mode?
What happened to the Miata? Most people I know beat the hell out of their Miata on the track and keep their C8 all nice for Saturday night.
I'd do manual mode so you don't accidentally change gears when you don't want to and upset the traction. I have no issue using ptm sport on a normal surface. Doesn't slow me down. If you feel it slows you down bump it up to R1
Undy (08-10-2023)
I plan on taking it easy on the Vette, just want to feel it on the track.
Mine is non-Z51 as well. Mag ride and perf exhaust.b Try Sport mode first in Comp mode (double press of TC button after switching into sport mode. This will be with some stability safety on. Car won't do anything bad if you ham fist it. Your choice on manual or auto shift mode.
Once you go around a few times try Race mode in comp mode. Much stiffer and flatter. Car will still not let you do anything dumb. For the brave, Track with traction and stab off. But be VERY careful as the car will step out easily into oversteer.
Non Z51 does not have PTM so no need to worry about.
Have Fun! The car is very precise and will go where you put it.
Mrchen (08-09-2023)
If you have non z51 you don't have ptm.
So for that I'd setup z mode to your preferences...
Suspension I'd try out in track mode.
Engine I'd put in track mode. You'll be using manual mode anyways.
Steering I'd use what you like best. For autocross I like your mode because the transitions are extremely fast and the light steering helps imo. But that's pure preference.
Brakes is out to track.
Then once in the right DRIVE mode you want to choose your level of stability control/ TC. I'd try competitive ESC mode. If you feel that's too intrusive you can hold the button down and all nannies will be off
I have a 2023 convertible with Z51 and Mag Ride, so my settings won't totally help you, but here they are:
I run the stock summer tires.
I use the street alignment.
I've had the two quarts of extra tranny fluid added.
I typically run in Track mode, using PTM Race1.
I manually shift. I normally don't mind the gears that the car chooses whilst driving on the street, but I don't care for its choices while autocrossing.
Usually on the courses I run, I'll start in first gear, upshift to second, and run that for most of the course, with an occasional shift to third on a longer "straight".
Bill B.
Bill B.
That's irrelevant for autocross.
Z51 package was designed for long multi-lap road course sessions with extra trans cooling, bigger brakes and different pads making them are more fade-resistant, which is necessary for long track sessions. With MSRC in TRACK mode, a non-Z51 should be equal in the short autocross sessions, and time between sessions to let things things cool down.
Even the AS4 vs. PS4S tire difference should be negligible in autocross. Spring Mt. pros found Micheliin UHP all seasons essentially equal to the summer tires for the first couple of laps, but after that, the AS4 begins to lose grip when very hot. That's not going to happen in a short autocross session. GM tests show the PS4S only 0.1g less than the AS4 in skid-pad performance.
Thats round-off error in an autocross session, but not on a road course. I used to compete in SCCA Solo, and the fastest cars didn't have any driver aids. It's an all-driver sport.
Having said that, type of car can make a big difference. I competed in an a Lotus Elise, which was also in the SS class along the with C6 Z06. We beat them most of the time.
bhvrdr (08-09-2023)
I dont' agree. The photo above is with the performance summer Z51 tires. Perform better than all seasons. Less front push, better turn in, and better traction in the rear coming out. More stable on HARD braking too.
Thats round-off error in an autocross session, but not on a road course. I've used to compete in SCCA Solo, and the fastest cars didn't have any driver aids. It's an all-driver sport.
Foosh (08-09-2023)
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Mine's a Z51 with Mag Ride. I run both full auto in D and manual shifting depending on the track.
proeagles (08-09-2023)
I'll be only one of two who say to leave in auto. With the sport/track settings, the DCT will stay in the right gear for an autocross course. It will likely shift into second and stay in second the whole time unless you have fairly long straight. I recall a video of Randy Pobst saying the DCT was so fast and accurate, might as well let it do all the work. Autocross is all about the driver all things being equal. If R compound tires are allowed in your class, they will make a difference despite what nay sayers say about not enough time to get heat in them. Back when I raced Miatas, I was consistently pounded by a driver who had them and when I switched, different ball game.
I found it shifting into 3rd far too often when I let the car do the shifting, and it wasn't on a particularly long straight section. It surprised me a little bit.
One of my fellow racers (who was corner working when I ran) noticed it as well, and asked me about it when I later joined him in the corner. He asked me "Are you shifting or are you letting the car shift?"
I told him that I had been letting the car shift that day (it was my first time autocrossing the C8), but that was the last time that I let the car shift while autocrossing.
Bill B.
CI-7-8-9-10 Veteran
At the same event, but in the ProSolo, my daughter finished on the podium in 2nd place racing my SSR car in SSPL (prepared cars), so she was behind the 8-ball from the beginning. Down on power, down on aero, down on wheel/tire size, .... She did beat a GT3, but lost to Michelle Wong. That was Michelle's 11th straight national championship, and daughter was not very far off.
Car performed very well in Lincoln.
