Best Driving Mode for Autocross
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
I have to disagree, though I suppose it could depend on the course.
I found it shifting into 3rd far too often when I let the car do the shifting, and it wasn't on a particularly long straight section. It surprised me a little bit.
One of my fellow racers (who was corner working when I ran) noticed it as well, and asked me about it when I later joined him in the corner. He asked me "Are you shifting or are you letting the car shift?"
I told him that I had been letting the car shift that day (it was my first time autocrossing the C8), but that was the last time that I let the car shift while autocrossing.
Bill B.
Bill B.
proeagles (08-09-2023)
The PS4S is only significantly better in long track sessions on a road course, once the tires get really hot.
I have run several autocross events in the past year since purchasing my 2022 Z51 and I have had the best times running in full track mode with traction control off completely. This past weekend I ended up third in my class getting edged out by a GT4 and GT3, I had just switched over to the Nankang CR1 tires and still working on getting the tire pressure figured out.
Not according to the pros at Spring Mt. who ran lap tests, found them equal for the first couple of laps and not significantly better on the skid pad either per GM. A 0.1g difference is not statistically significant. Driver skill way overcomes that, and a mediocre driver is not getting close to the g-limit.
Autocross wins are often decided by hundredths of seconds...not tenths. A better tire is everything.
don.bernow@mts.com (08-09-2023)
CI-7-8-9-10 Veteran
Again, for me it's course specific. If the gearing works for the course in full auto, then that's what I do. I still very much run manual mode too, but I find the auto mode is much more intelligent than I am. If I bog on 3rd gear on a given course, I typically switch to manual mode. For ProSolos, I depend on auto mode, as I need to launch control, and manual shifting in launch control is not as effective.
I'd turn everything off. At Ron Fellows we did autocross in one of the PTM modes that still keeps ESC on. A couple times I triggered ESC which slows the car down. If it's just a big parking lot course where you're only gonna hit cones if you spin I feel like ESC is too conservative. We only did manual mode but aside from the initial 1-2 shift you do the whole thing in 2nd gear. I don't think I'd want to be on auto, rather be in control than unexpectedly be in 1st or 3rd.
CI-7-8-9-10 Veteran
I would submit that once auto shifted to 2, it would stay in second because you are using the car in a vigorous mode and it won't shift unless it needs to. Ron Fellows runs everything in manual mode last I checked just for the hell of it. Makes you more engaged with car for all the people that just need to shift something. Once again I can't say enough good about this car and the DCT. When it's compared favorably to what is arguably the best on the planet from Porsche, that says a lot about how good the system is.
Spring Mountain only uses ps4s (summers). I asked them if they used all seasons because I had heard that rumor on this board and they do not. I've been there multiple times multiple levels.
They also do a lot of testing for clients and sponsors including Michelin and GM. They tested the OEM UHP all season, and the summer tire, and that's the basis for what they told me about the two, in particular, that the AS tire produced almost equal lap times to the summer tire for the first couple of laps until tire heat comes into play.
Autocross runs are far shorter than any single road course lap, and unless you're running back-to-back-to-back runs, heat doesn't come into play nearly as much as on a long road course.
Think what you want to think, but the available data say they should be very comparable in autocross. The PS4S really doesn't come up to full grip until it gets very hot, just like racing slicks. That's why you see a lot of spins in racing coming out of the pits on new ("cold") tires.
That's certainly not true of the average AS tire, and it's a testament to how good, and how close, Michelin's UHP AS4 has gotten to summer tire performance. GM would not have put it on C8 if that were not the case, and it's the first time they've used an all season tire on Corvettes in many generations for that reason.
Haha had a feeling that might be the case. Only other experience is from my older 6MT BMW on some parking lot courses, I had to rev and shift the **** out of it to get any power, C8 has a nice power curve for maintaining gears
I'm getting ready to order new number decals, I used magnetic ones on my Miata. This is probably a dumb questions but will a magnetic decal stick to a C8 door?
#33
Yep that is a dumb question........................static cling is the way to go. Stop by your local sign shop and see if they have the commercial grade static cling then spray a little soapy water on the cling and stick your numbers on the cling. Works great even if the car has ceramic coating.
#34
My daughter and I autocross all over the country in my 21. For most races I run in Track mode (turn dial twice to right, hit traction control two times, turn dial all the way to the last setting Race 2). If I do a ProSolo (drag race start with tree), I use Z mode with all settings maxed out, but steering. That stays on full soft (quick).
Mine's a Z51 with Mag Ride. I run both full auto in D and manual shifting depending on the track.
In Track mode with PTM set to Race 2 you have the nannies disengaged so you can break the rear end loose and get around some tighter corners.
#36
Some great advice in this thread! I am still experimenting but have been my fastest in track mode with all the nannies off and trans in auto. I have ran manual on a couple of runs, but for me there is already a lot going on and it took away from where my focus should be. For the last 2 years i have autocrossed a tesla model 3 performance. Nothing to think about there, just pin it out of every corner. The C8 is way more fun!
