Door sill protection?
Once sand/dirt gets underneath it will work like an abrasive. This is why bras are bad, especially in Florida. Sand gets underneath the contact areas, vibration does the rest.
I had my brother cut some custom vinyl. I have two layers. First layer is the black accent, then clear goes over all of it.
Platinum Supporting Vendor
I had these. They will make worse scratches in the paint than your feet. .. So I tried some felt buffers to stick on them to lift them away from the sill. .. When I took them off, the bufffers themselves had left marks that took me much time to rub out (with compound). Someone later told me I should have stuck the buffers to the car, rather than the sill protectors...
Just a heads up. .. (You can have mine if I can find them).. .
jay21 (08-08-2023)
For me at least, the issue is not the door sill itself but the plastic trim separating the door sill from the carpet. More than once I've dragged a heel across that and scuffed it.
#33
F-16 ED (08-19-2023)
#35
#37
if u want u can also ceramic boat the sill protectors
#38
Old thread, but I personally have much bigger issues kicking the lower door panel OR the plastic piece on lower front portion of the seat. At least I did in my C7. Just got my '24 so we'll see how the C8 works out. It feels like there is more room getting in and out compared to the C7.
#39
Those pre-fit tend to rub the paint. I've used clear plastic tabs where there was a tendency to rub the paint and it still looks like crap. Ended up with clear cabinet shelf plastic which I put down. Works great, no marring of sill and easily replaced and nearly invisible protection.
#40
I just use duct tape.
