Radar detectors?
#122
@INTRUDR Here's the mount I used from Amazon: https://www.amazon.com/gp/product/B0B94GX49V/
Same mounting posit@LIE2ME and is still available for $9.
EvanZR1 (07-13-2023)
#125
I've looked at the R8 and like it, but the lack of an iOS app is a deal breaker for me.
#126
Received 2,304 Likes
C4 of Year Winner (performance mods) 2019
#127
V1 G2 + VG app, mirror tap from eBay...
...mounted high; suction cups removed and replaced with scotch lock (velcro did not give confidence) ... quick removal when necessary.
The power cord (well secured under the mirror housing) serves as a tether should the device release unexpectedly.
JerryU (07-14-2023)
#128
LIE2ME (07-14-2023)
#129
WOW, I just swapped out my old Escort 9500iX for the new Max 360 MKII. Here are my initial observations (just sitting in the garage)
1. Both units use the same power cord (however plug connection is on the opposite side (Good to know if you have a power line permanently installed as I do).
2. You better download the manual for the Max 360MKII. The unit comes with no directions. Not even a "quick start" guide.
3. The Max 360 MKII is much larger than the 9500iX. About TWICE the size!
4. Same with the weight. The 360Max is 2-3 times heavier than the 9500iX. I mean, this thing weighs a ton.
5. Reference number 4 above, I don't use suction cups to attach the unit to the windshield, but if I did, I would be worried.
6. The color of the Max 360MKII case is sort of a blueish gray (instead of the basic black 9500iX), which means it does not "blend in" as well with the top of the dashboard.
Okay, that's it. I'll take the car out over the weekend and try to give new detector a good shaking out. Will report back with results...
Zormecteon (07-14-2023)
#130
Mount Radar Detector on the BACK glass?
Has anyone considered or better done an install that puts the RD on the back glass of the cabin rather than the windshield? Assuming one was mirroring the warnings to a phone or screen on the dash of the car, you'd see what you needed to see and it would be out of the visual line for obstruction or attraction to thieves. Not sure where we pick up the power but there is that mostly useless inductive charging slot on the back wall between the seats.
PaulCPO (07-16-2023)
#131
There is a fuse block underneath the center speaker that could be tapped for power but if I did it I'd want a hard wired remote display or at least a mute button for the times the Bluetooth connection misbehaves. If I did it that way I might as well run the power from the front.
Lefty32 (07-16-2023)
#132
RadarMounting
I just ordered the Escort MAX 360 MKII (Amazon has them $90.00 off on Prime Day, and I get another 6% off with my Amazon credit card). I will be retiring my trusty Escort 9500iX. I have been using the iX for over 10 years and it has saved my bacon MANY times. Only issue for me is that the antiquated firmware on this older detector did not do a great job of filtering out false K Band alerts. Got to the point that I disengaged K band reception, which got it to quiet down quite a bit, but of course, left me somewhat exposed. Anyway, the MkII is supposed to do a great job of filtering out all falsies, so all should be good at the end of the day. I'll report back.
on mounting on the waterfall would reaction time and incoming signal strength be lost?
#133
E-Ray, 3LZ, ZER, LIFT
Received 9,657 Likes
Doubt it as it’s only glass front or back.
#134
Escort Redline 360C - standard mount in the box
$11 eBay mount with VHB sticker instead of suction cup
$11 eBay mount with the magnetic piece from the standard mount instead of the articulating neck, with VHB tape
If I can find a suitable location for the third option once my C8 arrives, that is what I will use. Although I have ordered the flat magnetic mount on Amazon (see below) and will use one or the other of these.
#135
PS, the V1 arrows are nice - especially to alert you when a radar unit is approaching from the rear,
pacing or electronic speed determination.
#136
PhoenixM3 (07-18-2023)
#138
Well. After starting 2 RD threads of my own, stalking the Vortex site for months, and making a full circle from Escort to Valentine to Uniden, I am now back to Escort Redline 360. I had hesitated because Vortex kind of hammered the Escort a while back but with the updates seems most of that stuff is fixed. I was just about ready to pull the trigger on the Valentine but I decided I want a device that says "Hey stupid, there is a cop over there" without apps, and crap to figure out.
Sadly though, I have learned there is no such thing as the perfect RD.
I used V1G1's for 2 decades and wanted the V1G2 to win out. And my research found it to be almost unanimous, that the V1G2 used with JBV1 gives the greatest "coverage/protection" but..............
I wanted the RD with the least falses, without needing to continuously use Apps. These threads, Vortex You Tubes and the RDForum all directed me with those criteria to the Redline 360.
As you say: "there is no such thing as the perfect RD". Per what I have read, to me, the downsides of the Redline360 (compared to the V1G2) are (2 user and 1 performance):
1) No true mini remote display (showing arrows) for night time when I want to run dark mode,
2) Can't use a Visor mount (to leave it in place),
3) Redline360 is slower to react to Instant On than the V1G2 (or the Uniden). The new firmware upgrade made the reaction time marginally OK, but not as lightning quick as the other two.
Also - There are a not-insignificant number of 1Star, 2Star ratings on Escort's own website (at least they don't erase them - I hope). Much of it had to do with Customer Service and Shipping (of course), but some of the complaints were Technical. I mitigated that somewhat (especially the Shipping) by ordering one from Best Buy and will pick it up from the store on Fri (f2f). Also, Best Buy has $50 off if you become a "Plus Member" for $50 (for a year). A wash on cost, but the Plus Membership includes a 2 month return policy. And again, if needed, the Return/Reimbursement would be f2f.
I will add a Thanks to all the Posters here. This thread + one of the other RD threads that PaulCPO started had lots of informative testimonials that were key to my decision.
Now I got to get on eBay and Amazon to get the mounting hardware ordered.
#139
Indeed. A ton of info. More than I could process for sure.
No visor mount? Well, that stinks but not a deal breaker for me. I am hoping that I can get by with the blend a mount and windshield tint in non-friendly RD states.
The following 5 users liked this post by PaulCPO:
LIE2ME (07-18-2023),
rfkirk (07-18-2023),
saleen556 (07-19-2023),
TriGuyPNW (07-19-2023),
Zormecteon (07-19-2023)
