Screw in tire, repairable?
Thought it was a rock, upon further examination, it’s a screw. Tire is holding pressure. Is it repairable?
The following 4 users liked this post by gliot1:
Received 2,238 Likes
Yes
Is it correct tire can be repaired only once, after that, a new tire is required? This is a ZP tire.
The following 2 users liked this post by proeagles:
robob (07-03-2023),
ryanbrennan1009 (07-01-2023)
Received 2,378 Likes
Sweet Spot
Center of the tire is repairable. Discount Tire will fix it for free. Making an appt will save you some time.
Discount Tire (07-03-2023)
I had a nail in mine in almost the same spot last Monday, Discount Tire repaired it expertly at no charge on Tuesday, save yourself a lot of time, go to them first.
Received 19,362 Likes
'20-'21-'22-'23-'24
Based on the location of that screw, I would say that the tire is repairable - just ensure that a plug and patch method of repair is used.
Watch out at Discount Tire, aka America's Tire on the west coast. I took my daughter's car there to have the tire patched and they tried to sell me a set of tires. I passed and the car was at the dealer a week later where they noted that each tire had 6/32" tread left. Of course they fix tires for free since this insures a steady supply of potential victims. Be careful out there...
E-Ray, 3LZ, ZER, LIFT
Received 9,640 Likes
Have no idea if this was your case- BUT:
Some new tires have tread depths of 11/32 of an inch. A tire can have 6/32" in spots with a wear bar showing in another! Wear bars show @ 2/32" and can be worn uneven inside or outside etc with average much higher.
I don't wait for a wear bar to show before changing. A hydroplaning incident can be far more costly than a set of tires. Quoting:
"Most tiremakers agree that wet performance and a tire's resistance to hydroplaning decreases dramatically when the tread depth is less than 4/32 of an inch. Moreover, tires tend to wear unevenly, so check all of the grooves. If only one groove is under the legal minimum, it's best to replace the tire. Rotating your tires regularly ensures even wear."
Just say'n!
Just say'n!
Received 1,550 Likes
2022 C8 of the Year Finalist - Modified
Maybe there was a good reason they recommended new tires.
The following 2 users liked this post by MarkMeHopeful:
Discount Tire (07-03-2023),
hamta (07-02-2023)
Tire Smart
Just make sure when they take the tire off the rim, they don’t damage it. Take a picture beforehand.
First bad thing I've ever heard about America's Tire. I'm sure any given store might have a "bad apple" but America's tire has a great reputation and very positive reviews in general and on this forum. They've always done well by me - had factory tires replaced twice under their hazard warranty.
Know some think tips are not "needed" for car work (I also tip the great C8 Tech who works on my car.) 1st time he was reluctant to take it and I said heck I tip waiters and they don't hake close to your knowledge.
Undy (07-03-2023)
