Nail in tire, questions
UPDATE
After reading all the replies and Michelin's policy provided in a reply, I feel it will be best to order a set of rear tires.
Yes, it may be fine NOW, but one day, right in the middle of a tight corner having some fun, it may not be, and we all know how that would end.
i don't want to be the guy on YouTube or Instagram or TICKTOCK (lol) that ruined his Corvette for the price of a tire.
Thank you all for the input.
Smiles for miles.
Ugh...
A roofing nail in my right rear tire.
Losing pressure very slowly so it went through.
'22 C8, non-Z51
4,036 miles
Right in the center of the tread patch
Dealer doesn't have the machine to do Corvette rims so they plugged it so I could get home.
What are your thoughts on driving on it plugged?
I have not tracked the car and really don't plan to. I have other cars for that.
But I do enjoy some spirited driving on nice back roads.
Thoughts, past experiences, good or bad, are appreciated.
Smiles for miles.
Ugh...
'22 C8, non-Z51
4,036 miles
How did they plug it without taking it off the rim? Assuming that is what you mean by not having machine.
I thought a proper plug needed to be installed from the inside?
Either way if it was plugged properly I wouldnt sweat it. People drive on discount tire plugs/patches for thousands of miles. I know I have (and very spiritedly).
The following 2 users liked this post by Korbek:
carriljc (10-26-2023),
hippiefreak67 (05-23-2023)
A plug is done from the outside without removing the tire from the rim. Pull the nail, ram a reamer thru the hole to clean it up, stuff a glue coated rubber plug in and twist to seat and seal.
You may be thinking of a PATCH, where they remove the tire from the rim, smear glue over the hole and put a patch over and it is airtight.
I also have driven on patches until the tires need replaced, but not a plug, other than my tractor, 4 wheeler, and an old beater car years ago.
CaptainFester (05-23-2023)
A plug should be fine. I've plugged many tires and had no problems with them.
The following 6 users liked this post by Missouri Vet:
BearZ06 (05-23-2023),
CaptainFester (05-23-2023),
hippiefreak67 (05-23-2023),
Landru (05-23-2023),
and 1 others liked this post.
If a mushroom plug was used I wouldn't sweat it. However, if it was some type of noodle plug I'd have it repaired properly. Technically, the tire should be removed from the rim so a thorough inspection can be performed and then patched from the inside. Discount/America's tire will do tire repairs for free even if you didn't buy the tires there but I'm not sure about a tire that has already been plugged.
The following 2 users liked this post by RKCRLR:
Vega$Vette (05-23-2023)
I've plugged tires from the outside all the time at the golf course where I worked for 9 years in maintenance. Our equipment couldn't go 194mph however. Michelin recommends placing a patch on the inside of the tire I believe and that is what I would recommend. That's how NTB fixed a flat on my C8.
The following 2 users liked this post by spinsane:
proeagles (05-23-2023)
Per Michelin guidelines, plugging from the outside has rendered that tire "unrepairable," and it no longer retains its speed rating. One center tread block repair is approved by Michelin, but that requires dismounting, and a plug/patch placed inside the tire.
Of course, many folks have had outside plugs hold indefinitely. I suppose if you only drive tamely on sunny days, you may never have a problem. However, it's not uncommon for them to fail, and that's why they are only regarded as a "temporary" repair.
See link below for Michelin's policy.
https://www.tirerack.com/upgrade-gar...!&gclsrc=aw.ds
The following 3 users liked this post by Foosh:
Definitely take it to a tire place and get it patched from the inside. Plugging from the outside is just temporary. The patches also have a plug portion.....should run about 30-40 bucks
The following 2 users liked this post by oregonsharkman:
thunderstrike (05-25-2023)
The following 2 users liked this post by Wife said I could:
Larger dealers like forum dealer, Criswell, has all the latest Hunter equipment. I've had all my tires repaired or replaced there. They sell a lot of tires at competitive (Tire Rack) prices, and it's a large business for them since they are the 3rd largest seller of Corvettes. They keep all OEM Corvette Michelin tires in stock.
They've done the Michelin-approved interior plug patch for me a couple of times.
Things like this NEVER happen at a convenient time/location.
My tire pressure bell chimed, and pressure was getting lower as i drove. It was down to 22lbs when I stopped.
Unfortunately, I am not near any of them.
I have contacted my dealer, that does have all the right equipment, and I am ordering a new pair of rear tires.
Hippie freak. I’m in Saint Louis. What city do you live in? Sam
Received 4,741 Likes
