Frunk Hood Material ?
Received 2,240 Likes
Does anyone know if the frunk hood material is normal body panel fiberglass or carbon fiber? I would like to put my E-Zpass transponder in the frunk but I know from my C7 that carbon fiber will not pass its signal. Has anyone put their transponder in the frunk?
C8broughtmeback (05-15-2023)
Moderator
Received 3,594 Likes
The hood panel is SMC (sheet moulding compound) same as the fenders, etc.
brown007 (08-29-2023)
Received 6,949 Likes
SMC = glass-fibre reinforced polyester material. It is basically the same material as fiberglass, but not liquid and cloth, it comes in sheets, ready to apply heat and form into a mold. If the frunk was carbon fiber, that would be an option you would have to pay for.
The following 3 users liked this post by C5racecar:
E-Ray, 3LZ, ZER, LIFT
Received 9,657 Likes
My wife and her brother brother lived down the street from Robert Morrison and he recalls going for a ride in Morrison's 1953!
SIDEBAR
Corvette Body Materials
Fiberglass isn't the primary body material on Vettes these days, but the car continues a tradition of non-traditional, lightweight bodywork that began with the very first one off the assembly line in 1953. In fact, the reason conventional fiberglass isn't used any longer is because it's been replaced with better, lighter composite materials.
tadda (05-15-2023)
I placed my EZPass at the very front of the frunk and have had no issues in 2 months. Tag has been read with every pass.
Thanks so much for everyone clearing that up. I was hoping I could use the Frunk for my E-ZPass.
Moderator
As already stated, it is SMC (Toughened SMC Class A bonded and painted) per the following: https://www.compositesworld.com/arti...orvette-part-2
I believe Everyone that says it worries fine, but how do you test it? Just drive thru and hope?
Sounds to me like the testing has already been done and that's good news. The C6 with the same fiberglass worked fine.
Received 19,447 Likes
'20-'21-'22-'23-'24
Sounds like you will be fine with the transponder in the frunk.
Body structure: part B
"The new Corvette features not one but two trunks that, combined, hold 12.6 cubic-feet/0.36 cubic meters of cargo. Both trunks are produced in 42 wt-% chopped fiberglass/vinyl ester-unsaturated polyester (VE-UP) resin, but use different processes driven by geometry and mechanical requirements. The front trunk (frunk) is compression molded 0.95-specific gravity (SG) “float” sheet molding compound (SMC), while the rear trunk is formed via the proprietary PRiME (Prepositioned Reinforcement ensuring Manufacturing Excellence) process, a liquid compression molding (LCM) variant. The float SMC and the PRiME process were developed by processor Molded Fiber Glass Co. (MFG, Ashtabula, Ohio, U.S.). MFG produced all structural SMC and LCM’d parts on the car."Note, as that article states most body panels:
Exterior body panels are all bonded (inner/outer), painted, toughened 1.2-SG SMC (22-28% FVF fiberglass/UP resin, depending on component) from Continental Structural Plastics (CSP), a Teijin Group company (Auburn Hills, Mich., U.S.). Note even a lower % fiberglass content!
Still have friends in Ashtabula (where I managed and R&D Lab.) One own's another molded fiberglass products company said the higher volume body panels are not sufficiently profitable for MFG to consider investing in the added capacity to manufacture.
Simple forum search and you will find
On a serious note, look here.
https://www.corvetteforum.com/forums...te-status.html
Picked Iridium as it's one of the densest, highest specific gravity materials and it's used for some spark plug center electrodes.
Received 2,532 Likes
Interesting thread. When I lived in Illinois I had the big plastic EZ Pass that I needed to drive around Chicagoland. When I moved back to Georgia and got a PeachPass it's just a piece of tape with a metal strip in the middle of it that you attach just under the rear view mirror. You can't see it when you are driving and it barely shows when you are outside the car looking at the windshield. You almost have to be looking for it to spot it.
