So Chuck at Caughlin Says To Inflate your Tires to 50 PSI
For winter storage to avoid tire and sidewall damage during the winter months when the car is not being used. That’s a new one on me. Learn something every day
5632 (03-31-2023)
Popular Reply
03-31-2023, 10:24 AM
He's an idiot, and this isn't the first time he's said something dumb. Do not inflate your tires to 50 psi... We're not in 1960 anymore. That entire dealership is clickbait.
This is from that Goodyear website - and the attachment is from the Owners Manual:
Should I Remove My Wheels/Tires from the Vehicle for Storage?
If possible, it’s recommended to remove your tires from the vehicle for proper long-term tire storage. Tire removal allows you to isolate the conditions your tires are stored in, while removing stresses on the tire such as vehicle weight, temperature fluctuations, etc.Note: Another benefit of removing your tires for storage is that when it’s time for the tires to be installed on the vehicle again, the tires may be rotated from their previous positions. To do this easily, make a note of the placement of the tires on your vehicle at the time of removal, then they may be rotated accordingly when reinstalling them.
What if I’m Not Able to Remove My Tires from the Vehicle?
In situations where you are unable to remove the tires from the vehicle for storage, keeping the tires on the vehicle requires special considerations to do it properly. First, it’s ideal to remove the weight from the tires. This can be accomplished by resting the car on jack-stands or similar load bearing devices under the chassis of the vehicle. If you’re unable to remove the weight from the tires, it is recommended to have the vehicle completely unloaded, so only the minimum weight will be placed on the tires.If the vehicle is planned to be stored for long periods of time, plan to move the vehicle periodically (at least once every 3 months or once every 30 days for vehicles with high-performance tires featuring an overlay) during storage so that the tires aren’t subjected to a constant state of deflection affecting only one part of the tire. This periodic movement will help avoid temporary flat spotting that can develop from sitting static too long and minimize ozone/weather cracking.
Tires should be inflated to the vehicle recommended inflation pressure(s) – including the spare tire; and high-performance tires with an overlay should be inflated to the maximum inflation pressure shown on the sidewall of the tire. However, it is important to readjust the inflation pressure back to the inflation pressure shown on the vehicle placard before driving the vehicle."
Last edited by Andybump; 03-31-2023 at 03:21 PM. Reason: corrected based on additonal info posted later
The following 13 users liked this post by Kracka:
Bandit1 (03-31-2023),
Bcarr (04-01-2023),
Greg00Coupe (04-02-2023),
hamta (04-01-2023),
hcvone (03-31-2023),
and 8 others liked this post.
I don't do anything to my tires during storage but maybe next time I will over inflate them a bit.
I was told that modern tires won't suffer any permanent flat spots due to better materials and technology. I find that you will feel flat spots even after short periods of non use but after a few miles of driving they will go away.
The following 2 users liked this post by JDSC8VETTE:
AORoads (04-01-2023),
bullmarket (03-31-2023)
Received 2,901 Likes
St. Jude Donor '05-'06-'07-'08-'09-'10,'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
https://www.michelinman.com/auto/aut...-flat-spottingKey point from above link:
No, in general over-inflating your tires will not help flat spotting. In some cases it could make it worse. We recommend placard pressure and not higher.
Will over-inflating my tires help prevent flat spotting?
The following 6 users liked this post by golddog:
elegant (03-31-2023),
hamta (04-01-2023),
jay21 (04-04-2023),
Kracka (03-31-2023),
Red Mist Rulz (03-31-2023),
and 1 others liked this post.
If you want something to "cradle" your tires, you can park on thick rubber mats or sheets of pink foam insulation to get your tires off the concrete.
The following 3 users liked this post by blackvetterzo6:
I've not inflated that high, but for sure when going into storage I've always upped the PSI by 5-10 PSI over the cold spec, then air down when coming out. Worked for me for years now, no flat spotting.
Received 2,383 Likes
Sage Advice
If you are running 6.70/15 bias ply.
PhoenixM3 (04-01-2023)
Received 19,441 Likes
'20-'21-'22-'23-'24
I keep my tires at the recommended PSI as shown on the door sticker. Has worked very well for me over the years.
I've never had a vehicle on radial tires ever experience permanent flat-spotting, and I used to have a fairly large collection. I've seen temporary flat-spotting, which always disappears after the tires warm up and after no more than 10 miles of driving.
I've always kept tires inflated to manufacturer spec only. Sounds like someone is stuck in the bias ply era. Radial tires have been standard since 1976. Flat-spotting is another one of those outdated concerns that are passed from generation to generation. It might have been a problem for your father or grandfather.
Received 5,243 Likes
Gobble-de-gook.
Edward Going (04-02-2023)
The tires are from Michelin. Michelin says keep them at placard pressure (post # 5, above). I think Michelin knows better than "Chuck." Thinking you're smarter than Michelin just proves the opposite.
Isn't Chuck the guy who almost dropped a C8 off a lift the first time he worked on one, because he didn't use the right lift points?
hamta (04-01-2023)
What's most amazing is there's so many who believe everything they read on the internet. I don't know who this guy is, however a statement like that I now know he's an idiot.
Modern tires do not flat spot at least not to the point that won't be worked out by the time you have driven a block or so.
Now I know from experience that the original style bias-ply tires for the C2-C3s will definitely flat-spot if car is stored very long.
The following 2 users liked this post by Kevin A Jones:
Rapid Z (04-01-2023),
Spitfire Mk1 (04-03-2023)
The following 7 users liked this post by C5racecar:
ChiefBoats (04-02-2023),
frankjr (04-01-2023),
Ghost 23 (04-02-2023),
johnodrake (04-01-2023),
PhoenixM3 (04-01-2023),
and 2 others liked this post.
Received 4,743 Likes
Kracka (04-04-2023)
