Covering the engine vents while washing.
When I wash my car I take wide blue painters tape and tape off the engine vents to keep the water out. It's not perfect but it helps a bunch. Does anyone have something that works better? It would be nice if there was a 3 piece set of something to block them off.
Ron_Attleboro_MA (03-09-2023)
Popular Reply
03-09-2023, 02:00 PM
Four model years into production and still searching for an answer to a nonexistent problem .
Received 1,871 Likes
There are companies that make things that wedge in into the 6 spots, and the bottom of the glass, but they are not cheap. You can buy tape for the rest of your life and not come close to their price.
The following 2 users liked this post by SMOKN C8:
85vetteguy (03-09-2023),
Zormecteon (03-09-2023)
Ed Cordes (03-09-2023)
The following 4 users liked this post by Bburr:
The following 6 users liked this post by The Rooster96:
C8broughtmeback (03-10-2023),
killian96ss (03-10-2023),
proeagles (03-09-2023),
Ranger5 (03-21-2023),
Revmanii (04-21-2024),
and 1 others liked this post.
[QUOTE=SMOKN C8;1606366276]There are companies that make things that wedge in into the 6 spots, and the bottom of the glass, but they are not cheap. You can buy tape for the rest of your life and not come close to their price.[/Like most Corvette accessories you are correct, they are expensive. I will just get the 6" painters tape and call it a day.
Thanks!
Thanks!
SMOKN C8 (03-09-2023)
I put a large beach towel under each side. It’s a fast method and captures all the water that rains in.
The following 3 users liked this post by Maxie2U:
The following 10 users liked this post by BADBIRDCAGE:
4thC4at60 (03-10-2023),
DevilDog82 (03-10-2023),
Fishfryer527 (03-10-2023),
hawkgfr (03-09-2023),
John Harry (03-10-2023),
and 5 others liked this post.
I just washed mine today for the first time (got it yesterday) and had no issues cleaning up the water. I think using a pressure washer helps, because it's less overall volume than say a garden hose. Once I dried the car off I just popped the hatch, gave the surfaces and the glass a wipe and it took maybe a minute. I was expecting the hatch to spill water all over the freshly dried paint, from various crevices but it didn't. Personally I wouldn't worry about keeping water out, just use it as an excuse to clean in there. Engine bays are also not really considered sealed areas of the car, they're ok with some water. You don't want to pressure wash areas marked not to pressure wash (on all cars) but you can even pressure wash the engine bay. I do get it seems weird to see the water flowing in there. Unless you're only driving on sunny days, rain water is going in there any way at some point. Even on cars without exposed vents you get soap build up in the drainage of engine bays, trunks, doors, etc... it's all got to get washed at least sometimes.
The following 5 users liked this post by Revette:
JerryU (03-10-2023),
TNBatmobile (03-10-2023)
Even with the vents covered, water gets in the compartment around the seams. I just open it and dry it. Only a few minutes and the engine and surroundings usually need to be wiped off anyway.
The following 2 users liked this post by DaveDMW:
I have ridden the salt road several times.
After that, I washed water directly applied to the engine room twice to clean the engine room.
I'm worried, but I'd like to think it's okay because it's designed to run even in the rainy days.
E-Ray, 3LZ, ZER, LIFT
Received 9,655 Likes
First like you say water gets in around the hatch to body seams. I find only a few ounces on the rear flat section on either side of the cabin window. Now I'll not foolish and squirt the hose directly into the vents or the opening on the lower parts of the hatch glass that is also a heat vent!
I spray the car with soap foam device that fits my hose, no compressed air needed. Then use a hand mitt with soapy water washing mostly the lower areas and my side skirts, splitter front grill and rear facia. The I use the dial on my soaping device with a soft spray to rinse. I dry the car. Then I pop the hatch and with the corner of a towel pick up the few ounces of water. Then use that corner to wipe the dust and dirt that comes in thru those large fender vents every time you drive. Do those using painters tape etc just leave the dust and dirt?
After I wipe the engine cover and all flat parts with that wet corner of the towel. I use the bulk of the dry towel to clean all the flat surfaces and engine cover. Takes a few minutes.
I usually find these Threads from folks who don't yet have their car or got it and haven't yet washed it. Or those who started to use tape or those silly plastic covers that only cover the more obvious opening, not the lower opening on the lower hatch glass or hatch to body seams and didn't understand it's a non issue.
Sorry.
The following 2 users liked this post by JerryU:
I just let the water get in and then wash the engine bay afterwards. Takes about 5-8 more minutes and the bay is clean all the time.
The following 2 users liked this post by Ed Cordes:
killian96ss (03-12-2023)
Lamster (04-21-2024)
Received 19,439 Likes
'20-'21-'22-'23-'24
Makes sense and no need to spend money on something to cure what is really a minor issue.
Reminded of my old boss. Brilliant physicists who invented Plasma welding and cutting. He would walk thru our R&D Lab and if he saw an engineer working on something he thought foolish would say, "You're solving a problem not known to exist using a method known not to work!" He was a WWII Navy officer and statement was generally made with a few expletives deleted thrown in!
