Brakes, lots of dust!!
I finallly got my 23! Only waited 11 months and a couple weeks! Anyway, I was only able to drive it a couple days before we started getting snow and the salt came out! I got it washed and covered then put away for the winter. Well, in the 100 miles I drove, my wheels were covered with brake dust! They took quite a bit of cleaning. I had a 2010 ZR1 with chrome wheels which didn't require near the clean up! Are the brakes different on the C8s than earlier models? I've had an 88 and 85 also but never had as much dust to clean up!
Yes, it’s bad…. Shows up worse on silver wheels and tridents are a pain to clean. Really makes me want a set of MRR FO23’s in Carbon flash.
Ceramic pads. Do some searches on the subject here and you’ll find good solutions.
ednsd (12-12-2022)
Received 8,872 Likes
Yes, your ZR1 had carbon ceramic brakes which dust very little. Your C8 does not have those brakes, and yes they dust a lot.
E-Ray, 3LZ, ZER, LIFT
Received 9,643 Likes
Here is my many step by step pics/long caption PDF on How To Install low dust pads: http://netwelding.com/Ceramic_Pads.pdf
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
By all means...if brake dust bothers you, change the pads. You can find all the "here's how to make them easier to clean" tips, or you can just eliminate the dust problem once and for all, which is what I did on my C7 and C8. Makes life much easier if you like a spotless car. I went with the Carbotech 1521 on the C7, but with those being a good bit more expensive for the C8, I decided to try Powerstop Z26 on the C8 instead...and I've been happy with both pads on the respective Vettes, both in braking performance and lack of dust.
Received 19,388 Likes
'20-'21-'22-'23-'24
Changing the pads to low dust ones will solve your issue. Speak with the forum vendors that specialize in brake products - they can give you advice on which pads to use and a quote on the cost.
Received 4,684 Likes
The following 4 users liked this post by BIG Dave:
This is one of many reasons I didn't want the Z51 pkg. I never hand wash my rims and they always look clean with zero dust. I just use my foam blaster and rinse with my power washer.
This is something you pretty much have to deal with if you option the Z51. Everything has it's pros and cons and you just need to decide what's most important to you. It's like guys who have a Z06 or ZR1 and complain about the fuel mileage.
Received 1,992 Likes
Me too I am shocked at how easy it is to maintain the wheels on the base cars after always fighting the dust on my prior Z51 cars.
I was never motivated to buy aftermarket pads, I figured GM engineered the Z51 braking system the way they did, I paid for their expertise, why would I go aftermarket if I wanted the full benefit of Z51?
mefly2 (12-01-2022)
The stock Brembo Z51 pads are high dust track pads. The brake dust helps to reduce the brake temps so I am told.
Put some carbotech 1521 pads on there and you will be happy. Save the stock brembo pads for track days.
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
Part numbers for C8 Z51 are below.
F: CT28951F $284.00 Less 5%
R: CT28951R $214.00 Less 5%
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
The following 3 users liked this post by Adam@Amp'dAutosport.com:
Received 6,940 Likes
Powerstop Z26 pads are on my list of things to do once I get my Z51...
5632 (11-28-2022)
The following 3 users liked this post by DWS44:
