Carbon Flash Trim on Black C8?
In my area, and local car shows, I’ve actually never seen a black C8 in person. It’s my preferred color. Can you confirm that even on black C8’s, all of the front grill trim, side trim, and trim at the rear is still carbon flash on the stock C8? I circled the areas I’m referring to. I plan to order a black 1LT with no aero, but add the accessory low profile spoiler that comes in carbon flash. Just trying to figure out if I’d want to paint the spoiler body color, or leave it carbon flash. Can anyone post any pics of the carbon flash trim that picks up the difference in the 2 finishes?
KonaVette (10-29-2022)
Yes it’s still carbon flash. I even ordered my black C8 with carbon flash low rear spoiler and mirrors. When looking at the car at normal distances it’s hard to tell it’s different from the rest of the car. When you look close to it you can see the carbon flash difference. Most people just see a black car.
Cannot spec body color trim on black C8’s.
As noted in title, you cannot spec body color trim on black C8’s…at least you could not for a 2022.
Cheers!
Cheers!
…then leaving the accessory low rise spoiler carbon flash would be best…might avoid a mis-match actually since all the other trim is carbon flash…
Moderator
Here's the info from the Order Guide:
EFR Exterior accents, Carbon Flash, side vents and front/rear grille accents
1 - Also includes tonneau grille.
Standard on all trim levels, all colors
EFY Exterior accents, body-color, side vents and front/rear grille accents
1 - Not available with exterior color (GBA) Black. (1LT, 2LT coupe)
2 - Not available with exterior color (G1W) White Pearl Metallic Tricoat, (GAR) Carbon Flash Metallic or (GBA) Black. (3LT coupe 70th Anniv Special Edition)
3 - Not available with exterior color (GBA) Black. Also includes tonneau grille. (1LT, 2LT HTC)
4 - Not available with exterior color (G1W) White Pearl Metallic Tricoat, (GAR) Carbon Flash Metallic or (GBA) Black. Also includes tonneau grille. (3LT HTC 70th Anniv Special Edition)
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Best thing about black, is the carbon flash basically appears black, and it all just melds together. Hence why I bought my 6th black vette. Z06 will be black as well.
Received 5,231 Likes
It works okay... except it makes ya want then entire car in carbon-flash!
I think the low spoiler comes body color. The only way to get it carbon flash would be to order the 100 dollar carbon flash mirrors option which would also include carbon flash spoiler.
This one:
Moderator
Interesting. The Online Order/Reference Guide says they can't be ordered on Black:
ZYC Carbon Flash Metallic-painted outside mirrors and spoiler (when equipped), includes (DRG) Carbon Flash Metallic-painted outside mirrors
1 - Also includes Carbon Flash Metallic-painted spoiler when (Z51) Z51 Performance Package or (TVS) low-profile rear spoiler and front splitter is ordered. Not available with exterior color (GBA) Black. (1LT, 2LT)
2 - Also includes Carbon Flash Metallic-painted spoiler when (Z51) Z51 Performance Package or (TVS) low-profile rear spoiler and front splitter is ordered. Not available with exterior color (GAR) Carbon Flash Metallic (3LT with 70th Anniversary Special Edition) or (GBA) Black. (3LT)
1 - Also includes Carbon Flash Metallic-painted spoiler when (Z51) Z51 Performance Package is ordered.
