Cylinder deactivation defeat device question
Received 1,168 Likes
St. Jude Donor '21
As far as I know, there is not one for the C8. Some people are driving in manual shift mode, that disables V4 mode. Track mode does too, but I think that is impractical for street driving.
It doesn’t bother me, I don’t even hear it.
16falcon is correct. The Range disabler doesn't work on the C8, and there aren't any other devices available. Driving in Z mode with the engine/transmission set to track will disable AFM while letting you set the other items to something other than track. Or manual mode.
jay21 (10-06-2022)
Received 1,556 Likes
2022 C8 of the Year Finalist - Modified
You can only defeat AFM by shifting in Manual Mode, putting the car in Track mode, or using Z-mode with engine/transmission set to track (as described above.
PandaVette (10-06-2022)
I barely notice the transition at all. I did notice a "judder" on the C7, but the system in the C8 is much refined. I like the system. On a long interstate road trip, why not save some fuel?
The following 7 users liked this post by Foosh:
Fast Dawg (10-01-2022),
JScottH3 (10-06-2022),
JTBogus (10-01-2022),
Kracka (10-01-2022),
PandaVette (10-06-2022),
and 2 others liked this post.
Received 19,394 Likes
'20-'21-'22-'23-'24
Seems like the C8 works better in the AFM transition than the C7, at least that is what is being reported.
Chemdawg99 (10-06-2022)
I've only had my 2023 HTC for a week, but I can hear it when AFM kicks in.
C5racecar (10-30-2023)
The difference is negligible. The AFM traps combustion products in the AFM cylinders to act as springs. So the pressure in the AFM and non-AFM cylinders is similar. And AFM is only used at low throttle positions. It doesn't take much throttle to kick the engine out of AFM operation.
The following 5 users liked this post by RKCRLR:
Foosh (10-01-2022),
heysteveh (10-01-2022),
undecided1965 (10-07-2022),
Walt White Coupe (10-07-2022)
^ Very true. A barely negligible throttle increase reverts back to V8 mode.
On the sound, I wonder if there are variations in cars. I've been listening for it, and haven't heard a peep.
Moderator
Received 3,589 Likes
On my recent 2200+ mile trip I got as much as 31+mpg and the AFM system was not noticeable at all.
The following 6 users liked this post by johnodrake:
Chemdawg99 (10-06-2022),
M2Pilot (10-06-2022),
R23HTC (10-01-2022),
rmbakos (10-30-2023),
and 1 others liked this post.
Received 2,529 Likes
I never noticed it in my C7 either. I am guilty of playing a lot of classic rock very loud on stereo systems I custom built for my cars back in the day. That might explain it.
It was very noticeable on a C7 with a manual trans, but not so much with the automatic. On the C8, if it weren't for the indicator on the dash and the change in exhaust note which I can sometimes hear, I'd never know what mode it was in.
I often mute the stereo, but have MyMode set at max loud on the exhaust, and I've never heard anything. I also use the paddles most of the time even in auto mode. However, I have tested a dozen or so times listening for it with exhaust quiet in Tour, and nada.
Fast Dawg (10-02-2022)
Yeah AFM is great for highway MPG. 99% of my driving is not highway, and it cycles on and off quite a LOT. Yes I hear it switch, and yes the exhaust sound is different. While I appreciate the innovative feature, it detracts from my own experience. Track mode engine/trans is fine for defeating it, but it's far too eager to downshift with the slightest increase in throttle. And I don't want to paddle shift it all the time just to drive a v8 full time and not have hair trigger downshifts.
I hope Range comes up with something. I know this is a first-world problem, but c'mon.
Unfortunately, I suspect the heavily encrypted electronic architecture in the C8 will lock out devices like the range.
2022 C8 of the Year Finalist - Unmodified
In a 1000mi road trip last week all I noticed was I could hear (what I presume) are the AFM valves when it switched to V4 mode. To me, it sounded like a sucking of air like I hear on my truck intake when I juice it. I only made the connection because I had a lot of time to figure it out. I don't notice any difference between V4 and V8, other than the whoosh sound when it goes into V4 mode. There is no lag coming out of V4 mode either.
Drive it in tour and reap the mileage. I do not even notice the comings and goings of the 4 cyl mode. . My C7 had a shudder. especially when you hit a hill and it leaped into V8 mode. The C8 is great.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,107 Likes
