Paint chipping around headlights
How many C8 owners are having problems with paint chipping around the headlights? And what is GM doing to rectify this problem? I am attaching a photo of mine. I suggest everyone take a close look around your headlights.
That looks terrible!
Received 6,934 Likes
This is a well-known common problem....A simple forum search would reveal this thread below which discusses this....A TSB has also been released by GM addressing the problem...
C8 Paint peeling around both headlights
lv89019c8 (09-29-2022)
I don't know what would bother me more the paint popping or that seam from the PPF.
Kevin A Jones (09-29-2022)
Where did you buy your C8 from ? This is a very common problem and the dealership should have easily saw the headlight didn't have the proper spacing when they did the final inspection
My C8 does not have this problem.
No issue with ours.
I have it on the passenger side and plan on bringing my car in to have it repaired under warranty per the TSB this winter.
Received 1,991 Likes
Mine had no issues 11 months ago when I bought it. I found a small issue a few weeks back, so small I was able to easily touch it up. What my concern is will I have more issues? I thought this was a one and done problem that was found on a brand new car not something that occurs a year out?
As others stated this is a common problem and has been an issue on C7s as well. So what is GM doing to fix it; nothing that is working. As far as fixing the damage the dealer body shop should fix it under warranty.
I had that on one of my headlights. There's a bulletin on it. The dealer just took the headlight out, adjusted it, and did a touchup. That's your bulletin. They gave me the touchup paint.
PS: I wouldn't be too happy with that PPF. After a while you'll be replacing it.
I intend to have the gap inspection that is outlined in the TSB done during my PDI...
"The headlamp lens should have a minimum 0.5mm (0.02") gap between the lens and the body panel"
Lit (09-29-2022)
off topic, but seriously, what's the point of PPF. I've seen them get yellowed, and when they get old or need replacement, who knows if the paint will get damaged when taking off. I'd never put PPF or wraps on my car. Just be careful with the factory paint.
Received 19,375 Likes
'20-'21-'22-'23-'24
After the problems on the C7 you would think they would produce a car that did not have this problem. But it hasn’t happened yet.
