Exhaust…pops and cracks or no?
A C8 will be worth what you paid 3 years from now. An F Type will be worth half maybe? If that. Plus consider an F Type will spend equal time on the service drive as at your home. If you can afford a quarter million dollars for an Aston, you shouldn't be lurking here. No brag just fact.
And comparing notes from both marques' forums, I don't think it's safe to assume C8s spend less time in the shop than do F-type.
BMadden (12-25-2021)
My Ftype didn’t spend a day in the shop. My c7, on the other hand, had issues a few miles down the road from driving it new off the lot.
This statement alone tells me you really want the Jag and you are only here to get our approval. Well I approve go buy your Jag and pop your way down the road.
I have a 981 Boxster S with Sport Chrono in manual. In the Sport Plus setting, as you downshift and it rev matches, the sound is intoxicating. This is not some high school tuner pop and crackle. This is factory and the sound is just right. The C8 does not sound like that. And in my opinion, it comes down to how it was tuned. The Porsche on downshift, drops extra fuel into the exhaust for the crackle and pop. Perhaps due to EPA requirements, the C8 does not. It does crack at the very top of the rev range on up shift but that's it. Perhaps the Z06 will have that factory tune enabled.
As far as crackle and pop goes there were many who claimed the C7 didn’t do it but mine was very vocal. I think it was because it was a manual and when you revved it out and let up it would crackle and pop nicely. I think the C8 will do it but you would need to be in manual mode. I was able to make it crackle like I did with my C7.
Tuning
I installed high flow cats and it definately give off more bubbles and pops and you really hear the fast shifts, they pop. When slowing down in z mode or manually downshifting you really hear it. Very happy I put those on.
the real RacerX (12-26-2021)
thanks
One of my main criteria for a sports car is the exhaust note. I had a 14 c7 which had a good sound, but didn’t do much in the way of pops and crackles. I traded it for an F Type R which sounded like fire crackers going off constantly. I’m currently driving an AMG GLC 63S which is somewhere in between. I’m curious about everyone’s experience with the c8. Does it rumble like the Jag on downshifts or is it more muted like my c7 was? Any idea about the Z06?
IMMD (12-27-2021)
My Porsche Cayman cracks and pops when in sport mode. Maybe I'm showing my age, but in my day when a car did that it meant the carburetor was out of adjustment and was making the air/fuel mix too rich. Subtle effects however can sound good; I had an Audi TTS once which had a subtle pop when downshifting which was okay. But I think they overdid it in the Porsche and I find it a bit embarrassing when my car exhaust starts popping when cruising through the neighborhood at 25 MPH..
#33
I had an F type S a buddy of mine had to offload because he was having a baby....that thing roared...the electronics in the car were well behind where they should have been, but i loved that car....waiting on my 22 C8, it cant get here fast enough!
IMMD (12-27-2021)
#34
Let us know your impression of the exhaust once you’ve received it. I had an F Type R and it roared too. I believe they toned it down, but I loved it the way that it was. But I agree, the tech inside was a generation behind and since it’s essentially unchanged, it’s now two generations behind.
#35
They starting toning down the F-Type exhausts a couple years ago. They're nowhere near as loud now as the '14-'20 models were. With all the regulations now and the push towards EVs I doubt you'll ever hear a factory exhaust as good as those again.
#36
I agree. Makes me want to consider buying a used model. The carbon ceramic brakes with the special wheels and yellow calipers looked amazing on my 16 model. I should never have traded it.
Bird67 (12-27-2021)
#39
burble tunes are played out. GM made the right call
