Any quick lift owners/users
So I been needing a quick lift. But I want to get the 7000 TL so if can lift my Silverado for a tire rotation ,and another Collect car I am trying to purchase . if I am looking at it correctly they are all the same length of 60" if just the heavier weight rated unit makes its taller. Will it still fit under a C8 . I been on the look out for a sale but wanted to make sure I can get the 7000TL
wfoZ06 (12-19-2021)
Received 11,607 Likes
You want the 7000TLX that is 66", the TL is 60", it works perfectly fine, but you won't get to the front jack points. I use my 7000 60" all the time and it is rock solid and safe, some worry too much. Tip, if you're going to use it on the truck get the SUV/TRUCK adapters, you'll need them.
Here is a discussion about it.
https://www.corvetteforum.com/forums...es-and-no.html
joeyofblades (04-13-2024)
What is the difference between their TL and TLX models?
TL is 60" long and the TLX is 66". The 60" comes up a few inches short from the front jack point on a C8. Mine is 60" long and it is not an issue in the least. With the weight distribution on a C8, the rear jack points are what is VERY critical.
Maxie2U (12-19-2021)
Thats was it , all of there advertizing finally wore me down . I just purchased my 7000TLX with a wall hanger from there black friday sale . 350 0ff and free shipping
From previous post it was determined we need a Exstended version for a C8 for the distance needed between the jacking pucks . and I chose the 7000lb lift for my Silverado and wifes SUV
Ill let you know when I get it , First job front grill gaurds I never installed
