Z51 ELSD vs non Z51 LSD
#41
Hey gang, brought this old thread up to see if somebody knows for certain what type of LSD the regular C8 has, since it wasn't mentioned when somebody asked here. So is it a clutch-type, or Torsen? Hopefully the latter, but I suspect the former. I don't want any electronic trickery myself, plus need A/S tires, and will never track the car, so I'll get a non-Z51. But want to know what kind of LSD it comes with. Figured it was better to resurrect a relevant old thread, rather than starting a new one, but let me know for next time. Thank you.
#42
#43
Standard mechanical LSD with clutch plates.
Phil1098 (12-06-2023)
#45
I live in a rural, mountainous area. A road I drive on daily has sharp left hand turn on a steep upward grade that opens up to a one of the few passing lanes on the road. When I start my pass I may be going ~20 MPH while turning left to finish the curve plus getting around the car in front then turning right to straighten out, all while accelerating. The C8 Stingray has ample power to break loose under these conditions if too much power is applied.
I find the base C8 far more than enough for literally any sane driving scenario on public roads.
Bald Guy (02-14-2024)
#46
Here is another document that lists the advantages of eLSD:
https://static.nhtsa.gov/odi/tsbs/20...83145-9999.pdf
• Driving straight down the road - The eLSD system
will have a bit of coupling to add stability and
on-center steering feel. This will be a relatively
small amount (around 10% - 15%) and the number
will decrease slightly when making a lane change
or other steering input.
• When applying the throttle - The system will
increase the coupling under heavy throttle. The
driver may see around 40 - 50% coupling under
heavy acceleration in a track setting. This is to
maximize rear traction while cornering, while still
maintaining the feel of how the car handles
throughout the turn.
• Extreme lane changes and slalom events -
The largest coupling will occur during the most
aggressive dynamic maneuvers. The eLSD
clutches will nearly lock (100%) to add stability at
the right moment but open back up to allow the
vehicle to steer through a double lane change at
precisely the right times.
• Winter driving - If the vehicle is being driven in the
winter (being equipped with the appropriate tires),
and the driver is attempting to accelerate from a
stop with one wheel on ice and the other on dry
pavement, he or she will notice that the clutch
torque will increase on the DIC as a result of the
single wheel slipping. This will transfer torque to
the wheel with more available traction so that the
vehicle will accelerate smoothly.
Some will say that this is just marketing or that magazines just say things like this to get readership. But when they align with my own experiences I tend to go with them over posts on social media.
#47
Received 2,289 Likes
C4 of Year Winner (performance mods) 2019
#48
blvd cruiser vs mountin runnerit seems to me. In part for me I know it is there when I want it. is it a wise use of money probably not neither is the car in general. ymmv leave it at that
#49
Received 11,607 Likes
If you're driving on the street to the level that an eLSD is going to save you vs. losing it with a mechanical LSD, you're an idiot that will be dead soon anyway. I've driven both cars and it is such a small degree of difference, that the other variables (road surface, conditions, temperatures, etc.) will mask whether it's doing anything for you or not.
The following 5 users liked this post by Phil1098:
Acpantera (12-06-2023),
JVi (12-06-2023),
Korbek (02-22-2024),
Scruff Vette (12-07-2023),
wbear (12-06-2023)
#50
I've cited multiple sources discussing the advantages of an eLSD on the street, can you cite any sources that say otherwise? (other than social media posts by individuals).
#51
Only my own personal experiences. To be fair I tend to be an adaptive type person, I make the most of whatever I'm given and try to make the difference with skill. WAY too many times I've been at a track and have seen skill makes a far bigger difference than mechanical stuff.
#52
#53
#54
That's what I thought, but thank you very much for the confirmation.
#55
Of course. But now you are comparing apple to oranges. If you put Max Verstappen in a Camry TRD and he beats someone driving a C8 Stingray around Spa , you can't say the Camry TRD is the better car. In other words, you can't use that data for a valid comparison of cars. Put Verstappen in that C8 with the ELSD and run some laps. Then send him out in the same car but with a standard LSD. That gives you some data to make valid comparisons.
#56
The problem with your explanation is we aren't talking about a world champion, but regular Joes, and at that point, THEY are the limiting factor, not the car, they get no where near full capability of the car, that's my point. So a slight mechanical improvement makes no difference in the least.
#57
What often seems to get lost is the value of things that only make a difference on the track vs things that can be perceived at less than the limits. Just because something makes a small difference at the limits of the car doesn't mean it doesn't have a benefit when driving at less than the limits.
The following 2 users liked this post by RKCRLR:
tadda (12-06-2023),
Zaro Tundov (12-14-2023)
#58
Received 1,551 Likes
2022 C8 of the Year Finalist - Modified
[QUOTE=Korbek;1603738066]Tried searching for this but couldn't find a clear answer. What EXACTLY is the benefit of the Z51 ELSD vs the standard LSD on the C8? The ELSD would be my main reason for getting the Z51 package, but if the standard LSD is mechanical I feel like that's one less electronic gremlin that might pop up.[QUOTE]
Why would the ELSD be your main reason for getting the Z51 package? You get a lot more than the differential with Z51.
#59
Sr.Random input generator
My 2 cents:
eLSD makes the car feel smaller. It opens up the LSD when you're turning, drastically reducing understeer, and locks it back up when you're accelerating out of a turn. There's a reason why C7's handling was so much better than C6, and wowed owners, often being called a sweetheart to drive even when everything is turned off, without the snap oversteer drama of the C6, which was always around the corner if you pushed it beyond its limits.
The same holds for C8. True, we need much less need of traction for acceleration, but it can still understeer like a pig. eLSD and wider front tires can fix it all : )
I'd always get the eLSD. If you're worried about reliability, its track record is actually pretty good so far, and it can theoretically keep the underlying LSD in better condition by using it only when it's right...
#60
E-Ray, 3LZ, ZER, LIFT
Received 9,640 Likes
I wrote this 10-page PDF after reading a long "Ask Tadge" post about eLSD. He let the engineer who developed the software write most of it. My summary is a lot easier to follow. I put the complete original Forum post at the end but need to read slowly and several times! http://netwelding.com/eLSD_VS_Posi.pdf
Had read eSLD was invented by GM originally for FWD cars to deal with torque steer. had that in spades oin my turbo FWD car!! The engineer Jason Kolk discusses how the Cy Positracton needs to 1st slip and can then produce a maximum 88 ft-lbs locking force while the eSLD produces ~15 time that level of locking force and controls not just when a wheel is slipping. His algorithm is very complex and has many inputs defining which rear wheel gets how much locking force at all times.
I have several references in the appendix. There is an hour video by a Professor Kelly who takes ~6 Positraction apart showing how they work. That includes a Torsen. Another video shows graphically what I had called "sloppy spider gears" that make Posi work! They are not sloppy but the lateral force on the 90-degree spider gears is what loads the clutch packs in that old Posi design used in the Base C8!
Zaro Tundov (12-13-2023)
